Use-cases of AXI3 unaligned transfers
Hi all,
I cannot think of a good usecase of unaligned transfers in AXI3.
- For unaligned write, a master can anyway use aligned write + write strobes.
- For unaligned read, a master can use aligned read, then decides which data part of the first beat to use.
Can someone give an example of usecases of using AXI3 unaligned transfers?
Thank you.
Best regards
Diandian
