Performance effect because of removing some instructions from ARMv8?
I was going through the ARMv8 Architecture Reference Manual and I came to know that it does not support many instructions that were previously supported by ARMv7 architecture. For example ARMv8 does not support conditional codes and have a seperate instruction CSEL for implementing the same. On further reading I came to know that to reduce the load on instruction encoding and because of better branch predictor conditional support has been removed. However as I came across more instructions I found out that ARM has also removed  the RSB instruction instead you need to use a combination of SUB and NEG instruction to achieve the same. My question is that whether increasing the number of instruction does not increase the number of cycles required to execute that instruction. Similarly you can't load multiple registers onto stack, instead only a pair of registers at a time. Similarly there are various neon instructions in ARMv7 that do not have an equivalent instruction in ARMv8 so doesn't that affect the performance of the program?
