The latest 64-bit architecture can on both AArch64 and AArch32 state.
Can someone tell me how to utilize this feature so that I can seamlessly integrate algorithms (which are optimized with 32-bit and 64-bit instructions) with applications which are build for 32-bit and 64-bit modes.
Here is the specifics of situation which I am facing right now.
I want to link an ARM shared library which is optimized with 64-bit instructions with my application which is built in 32 bit mode.
At the time of linking I am getting the following error. "skipping incompatible xxxx.so file".
My build environment is android and unfortunately I don't have the option to build my application in 64-bit mode.
Appreciate your help with inputs.
Thanks, Prasad
Execution state (AArch32/AArch64) can change on when you take or return from an exception, and there is a change of Exception level (EL). There also restrictions on how you can mix 32-bit and 64-bit levels. Below is a slide we use is training to illustrate this:
What this means is that you could host a mix of 32-bit and 64-bit applications under the same 64-bit kernel. But you can't, for example, dynamically link a 32-bit app against a 64-bit shared library (or vice verse).
Assuming my OS has a syscall to switch from AARCH32 to AARCH64, it should be possible to mix 32-bit and 64-bit code. But which major OS and toolchain would implement this? Usually it's easier to compile the app as 64-bit if there is a 64-bit library to be used. Besides memory footprint concerns, is there really anything that prevents switching to 64-bit ?
Actually, there might be a few use cases where somebody wants to run a 3rd party 32-bit library with 64-bit code. There this switch-syscall could come handy. And in your case you'd build a 64-bit wrapper application then that runs most of the actual app as 32-bit code. Just for the 64-bit library you'd use a trampoline via the 64-bit wrapper to call the 64-bit library then.
