Basically I want to provide delay of 15 clock cycles for writing and reading through axi4 bus .Is it possible?
Hi preet729,
As "yasuhikokoumoto" says, we would need to know what is driving this requirement before anyone could suggest how to achieve this.
The interconnect logic between your master and your slave should be trying to pass information as quickly as possible, so it would be rare to see anything intentionally adding 15 cycles of delay.
Instead my first thought would be that if a master or a slave needs to delay any transfer completing on any channel, both the transfer source and the transfer destination have full control over the transfer timings using the AXI VALID and READY handshake signals.
So if for example your slave required at least 15 cycles between an AW channel transfer and the first W channel transfer, the slave can simply hold WREADY low for that amount of cycles.
Register Slices are there to break timing long paths, so adding up to a couple of clock cycles of latency depending on the design, but not 15.
You can add buffers in some ARM interconnects to data channels, but these will still try to pass the data from source to destination as soon as possible, so just adding one cycle of registering before making the data available to the destination device. Write data channel buffers can have something called "tidemark" levels which will stall the buffered write data until sufficient write data is buffered, or until the WLAST data transfer, but again not really guaranteeing any 15 cycle requirement.
So I would suggest that the component needing the 15 cycle delay should use the available READY and VALID handshake signals to implement the delay, unless you can explain why that isn't possible in your system, and what is driving this requirement.
JD
Thank you so much for your replies.
I am using memory controller block(Xilinx) and I need to delay the read and writes for 15 clock cycles so that I can modify the data being written to memory. Xilinx uses AXI bus . So I was thinking to delay the data when present in AXI bus. I have tried to delay the reading and writing but it has corrupted the data. I need to know where can I delay the data in AXI bus. And I have not made register slice myself . I was using the inbuilt AXI register slice to do so.
Also as said by you if i try to delay the data between aw and w channel. Then how will my system behave under burst mode. Because according to me in burst mode aw channel will be utilised once. As consecutive addresses will be calculated by the axi itself.and therefore i wont be able provide delay to each data in burst mode.
All suggestions are welcome
Regards
Preet
Sir
As you can see from the diagram I have taken from the manual of AMBAaxi it states that overlapping read bursts can occur(second address can be sent) without the first data being read back. I have thought of an alternative to this option:
shall i stop the handshaking
axhandshake=arvalid & arready;
instaed
axhandshake=arvalid & mask_arready;
I shall mask arready such that handshaking is not possible.
Also by making outstanding one you mean that the master cannot send second address before first data from first read transaction is read back?
Preet Kaur Walia
Hello Preet Kaur Walia,
Yes, you shall.
Yes, it does.
Best regards,Yasuhiko Koumoto.
I am working on the read and write as per your suggestions.
The read is working fine but write is not.
As you mentioned the write will work similarly but it does not.
If I do a single write it is getting written on memory without delay(I am assuming the first data mask is not working for it)
Burst is not working.
in the write case, you should swap the meaning of data READY and VALID.That is, RREADY to WVALID and RVALID to WREADY conversions will be needed.
always@(posedge CLK) begin if(~ARESETN) WADDR_DONE <= 0; else if(AWVALID&masked_AWREADY) WADDR_DONE <= 1; else if(BVALID&BREADY) WADDR_DONE <= 0; end always@(posedge CLK) begin if(~ARESETN) FIRST_WDATA_MASK <= 0; else if(AWVALID&masked_AWREADY) FIRST_WDATA_MASK <= 1; else if(WADDR_DONE&WVALID&WREADY) FIRST_WDATA_MASK <= 0; end always@(posedge CLK) begin if(~ARESETN) wcounter <= 4'h0; else if(WADDR_DONE&masked_WVALID&masked_WREADY) wcounter <= 4'hf; else if(wcounter!=4'h0) wcoubter <= wcounter -1 ; end assign mask_pre = (wcouner != 4'h0); assign WREADY_mask = FIRST_WDATA_MASK | mask_pre; // CHANGE! assign WVALID_mask = mask_pre; // CHANGE! assign masked_WVALID = WVALID & ~WVALID_mask; // RVALID for master assign masked_WREADY = WREADY & ~WREADY_mask; // RREADY for slave assign masked_AWREADY = ~WADDR_DONE & AWREADY; // this make outstanding 1
Best regards,
Yasuhiko Koumoto.
The write is still not working.
i have a doubt. According to the timing you have assumed it states that during a write transaction the wvalid will be asserted after awready.
But in the manual ambaaxi it has been quoted that "
It is important that during a write transaction, a master must not wait for AWREADY
to be asserted before driving WVALID. This could cause a deadlock condition if the
slave is conversely waiting for WVALID before asserting AWREADY.
Then the logic would fade.
Hello Preet Kaur Walia.
I am sorry. I forget the current First_WDATA_Mask would be too late to stop the first data cycle.
I think that if the reset value of First_WDATA_Mask was '1' and it would become '1' at every writing done (BVALID&BREADY), it might go well.
always@(posedge CLK) begin if(~ARESETN) FIRST_WDATA_MASK <= 1; else if(BREADY&BVALID) FIRST_WDATA_MASK <= 1; else if(WADDR_DONE&WVALID&WREADY) FIRST_WDATA_MASK <= 0; end
I have done the following change to the code and it seems to work.
As we donot know that awready will be high before or after wvalid. Therefore there is possibility that first data mask will remain 1 as this condirion may not get true
the changed code
regards
I doubt your suspicion (or maybe experiment result?) "if(WADDR_DONE&WVALID&WREADY)" might not become true because WVALID and WREADY should independent according to "A3.3.1 Dependencies between channel handshake signals" of AXI specs.
Actually, there would be some wrong scenarios with your implementation of "else if(WADDR_DONE & WREADY)" and the reset value was '0'.
If First_WDATA_Mask reset value was '0', it cannot handle the following scenario.
I think almost all case would be the <2> timing.
And "else if(WADDR_DONE & WREADY)" would not handle the following scenario.
This would be the same situation with "else if(WADDR_DONE & WVALID)".
So, I would like to propose the following description.
always@(posedge CLK) begin if(~ARESETN) FIRST_WDATA_MASK <= 1; // new change else if(AWVALID & masked_AWREADY) FIRST_WDATA_MASK <= 1; else if(WADDR_DONE & WREADY & WVALID) // should not change FIRST_WDATA_MASK <= 0; end
How about this?
Otherwize.
always@(posedge CLK) begin if(~ARESETN) FIRST_WDATA_MASK <= 1; // new change else if(AWVALID & masked_AWREADY) FIRST_WDATA_MASK <= 1; else if(WADDR_DONE & (wcount==4'hf)) // new change FIRST_WDATA_MASK <= 0; end
None of the solutions seem to work and I am not able to figure out the reason.
it's sad news.By the way, you said that if the following logic was used, it went well.
always@(posedge CLK) begin if(~ARESETN) FIRST_WDATA_MASK <= 0; else if(AWVALID & masked_AWREADY) FIRST_WDATA_MASK <= 1; else if(WADDR_DONE & WREADY) //change FIRST_WDATA_MASK <= 0; end
If it is correct, I guess that your master would not assert WVALID until getting WREADY from the slave. But it would violate the AXI specs.Can you confirm it?If you can confirm it, I should compromise the description above.To the contrary, if your slave would not assert WREADY until getting WVALID from the master, "else if(WADDR_DONE & WREADY)" would be replaced for "else if(WADDR_DONE & WVALID)".
By the way, I have found something was wrong."else if(AWVALID&masked_AWREADY)" would be strange (also in the read case).I'm sorry but I think masked_AWREADY should be AWREADY.
I am afraind WADDR_DONE would not become "1" with the previous description.Therefore, the logics would be the following.
always@(posedge CLK) begin if(~ARESETN) WADDR_DONE <= 0; else if(AWVALID&AWREADY) WADDR_DONE <= 1; else if(BVALID&BREADY) WADDR_DONE <= 0; end always@(posedge CLK) begin if(~ARESETN) FIRST_WDATA_MASK <= 1; else if(AWVALID&AWREADY) FIRST_WDATA_MASK <= 1; else if(WADDR_DONE&(wcounter==4'hf)) FIRST_WDATA_MASK <= 0; end always@(posedge CLK) begin if(~ARESETN) wcounter <= 4'h0; else if(WADDR_DONE&masked_WVALID&masked_WREADY) wcounter <= 4'hf; else if(wcounter!=4'h0) wcoubter <= wcounter -1 ; end assign mask_pre = (wcouner != 4'h0); assign WREADY_mask = FIRST_WDATA_MASK | mask_pre; // CHANGE! assign WVALID_mask = mask_pre; // CHANGE! assign masked_WVALID = WVALID & ~WVALID_mask; // RVALID for master assign masked_WREADY = WREADY & ~WREADY_mask; // RREADY for slave assign masked_AWREADY = ~WADDR_DONE & AWREADY; // this make outstanding 1
How about them?I'm sorry for you inconvenience.
The condition
if(~ARESETN)
end
should work fine considering that wvalid and wready need not be high together. Therefore, it might be possible that wvalid has gone high for a clock cycle and aftersometime wready goes high. Data mask should go low after that. Therefore it would not deviate from the AXI specification.
if the releasing the FIRST_WDATA_MASK only by WREADY made your system working fine, it's a good news.I think the characteristic of "wvalid has gone high for a clock cycle and aftersometime wready goes high" would be strange because the assertions (i.e. go to High) WVALID and WREADY should be independent.If the master makes WVALID high before the slave makes WREADY high, the FIRST_WDATA_MASK logic cannot stop the data cycle.The logic will only go well if the WVAID of the master will go high after the slave would make WREADY high.Anyway, there would be the timing WVALID and WREADY will be High at the same and I wonder why "WADDR_DONE & WVALID & WREADY" would be wrong for de-asserting FIRST_WDATA_MASK.The only possibility would be WADDR_DONE was '0' at the timing when "WVALID & WREADY" was '1'. These are the cases <1> and <2> of my previous post.I will propose the new condition for releasing FIRST_WDATA_MASK.Could you please try it?
always@(posedge CLK) begin if(~ARESETN) FIRST_WDATA_MASK <= 1; // new change else if(AWVALID & AWREADY) FIRST_WDATA_MASK <= ~(WVALID & WREADY); else if(WADDR_DONE & WVALID & WREADY) FIRST_WDATA_MASK <= 0; end
Best regards,Yauhiko Koumoto.
I am working on it. Also I had a query that in the write case ,
According to me the following scenario should be followed:
We should mask wvalid as we need to stop the wvalid from the CPU from going to the slave otherwise, it will do the write transaction as and when wvalid is high.Slave will then send wready (telling the CPU it is ready to accept more data).
Whereas we are working on the contrary. As it can be seen from the first data mask situation, wready is being masked and wvalid is being sent to the slave. Therefore, there is a possibilty that slave has already written the data to memory before we are providing the delay. (in the first data mask situation we are only masking the wready)
This is not right. It has possibility of deadlock. The wvalid and wready should be independent.
No, we consider two cases which wvalid is faster than wready and wready is faster than wvalid.
I'm sorry. You are right.assign WVALID_mask = mask_pre;would be alsoassign WVALID_mask = FIRST_WDATA_MASK | mask_pre;
It does not work .
I am very sorry for your inconvenience.
I have debugged and verified the codes on a real simulation environment.
I have observed that they had went very well,
I hope this will help you.
module AXI_W_DELAY15( CLK, ARESETN, AWVALID, // from a master AWREADY, // from a slave WVALID, // from a master WREADY, // from a slave BVALID, // from a slave BREADY, // from a master WLAST, // from a master masked_WVALID, // to a slave masked_WREADY, // to a master masked_AWREADY // to a master ); input CLK; input ARESETN; input AWVALID; input AWREADY; input WVALID; input WREADY; input BVALID; input BREADY; input WLAST; output masked_WVALID; output masked_WREADY; output masked_AWREADY; reg WADDR_DONE; reg FIRST_WDATA_MASK; reg [3:0] wcounter; wire mask_pre; wire WREADY_mask; wire WVALID_mask; always@(posedge CLK) begin if(~ARESETN) WADDR_DONE <= 0; else if(~WADDR_DONE & AWVALID & AWREADY) WADDR_DONE <= 1; else if(BVALID & BREADY) WADDR_DONE <= 0; end always@(posedge CLK) begin if(~ARESETN) FIRST_WDATA_MASK <= 1; else if(WADDR_DONE & (wcounter==4'hf)) FIRST_WDATA_MASK <= 0; else if(wcounter==4'h0) FIRST_WDATA_MASK <= 1; end always@(posedge CLK) begin if(~ARESETN) wcounter <= 4'h0; else if(wcounter!=4'h0) wcounter <= wcounter -1 ; else if(WADDR_DONE & WVALID & WREADY & ~(WLAST & masked_WREADY)) //!! wcounter <= 4'hf; end assign mask_pre = (wcounter != 4'h0); assign WREADY_mask = FIRST_WDATA_MASK | mask_pre; assign WVALID_mask = FIRST_WDATA_MASK | mask_pre; assign masked_WVALID = WVALID & ~WVALID_mask; // WVALID for master assign masked_WREADY = WREADY & ~WREADY_mask; // WREADY for slave assign masked_AWREADY = ~WADDR_DONE & AWREADY; // this make outstanding 1 endmodule module AXI_R_DELAY15( CLK, ARESETN, ARVALID, // from a master ARREADY, // from a slave RVALID, // from a slave RREADY, // from a master RLAST, // from a master masked_RVALID, // to a master masked_RREADY, // to a slave masked_ARVALID,// to a slave masked_ARREADY // to a master ); input CLK; input ARESETN; input ARVALID; input ARREADY; input RVALID; input RREADY; input RLAST; output masked_RVALID; output masked_RREADY; output masked_ARVALID; output masked_ARREADY; reg RADDR_DONE; reg FIRST_RDATA_MASK; reg [3:0] rcounter; reg next_rlast; reg next2_rlast; reg RVALID_delay; reg done_raddr; wire rmask_pre; wire RREADY_mask; wire RVALID_mask; always@(posedge CLK) begin if(~ARESETN) begin next_rlast <= 0; next2_rlast <= 0; done_raddr <= 0; end else begin next_rlast <= (rcounter == 4'h1); next2_rlast <= next_rlast; done_raddr <= RLAST & masked_RREADY; end end always@(posedge CLK) begin if(~ARESETN) RADDR_DONE <= 0; else if(~RADDR_DONE & ARVALID & masked_ARREADY) RADDR_DONE <= 1; else if(done_raddr & (next2_rlast & ~(RVALID & ARVALID & ARREADY))) //!!! RADDR_DONE <= 0; end always@(posedge CLK) begin if(~ARESETN) FIRST_RDATA_MASK <= 0; else if(ARVALID & masked_ARREADY) FIRST_RDATA_MASK <= 1; else if(rcounter==4'hf) FIRST_RDATA_MASK <= 0; end always@(posedge CLK) begin if(~ARESETN) rcounter <= 4'h0; else if(rcounter!=4'h0) rcounter <= rcounter -1 ; else if(RADDR_DONE & RVALID & RREADY & ~next_rlast) //!! rcounter <= 4'hf; end assign rmask_pre = (rcounter != 4'h0); assign RREADY_mask = FIRST_RDATA_MASK | rmask_pre | next2_rlast; assign RVALID_mask = FIRST_RDATA_MASK | rmask_pre | next2_rlast; assign masked_RVALID = RVALID & ~RVALID_mask; // WVALID for master assign masked_RREADY = RREADY & ~RREADY_mask; // WREADY for slave assign masked_ARREADY = ~RADDR_DONE & ARREADY; // this make outstanding 1 assign masked_ARVALID = ~RADDR_DONE & ARVALID; // this make outstanding 1 endmodule
The write does not seem to work for me. Which environment have you used? I have not tried read yet.
the environment is CPU and Flash or L2 cache path of a certain actual SoC.
Why do you think the write does not work?
Can you show me the write channel behavior of your environment?
Do you have any timing diagram of the write transaction?
Doesn't it issue the write interleaving?
The write logic is not more difficult than the read.
The main bad point of my previous logic was the priority of set/reset for the wcounter.
I will attche the timing charts of 4 burst and 1 burst cases.Could you let me know if there are anything strange?
(1) 4 Burst
(2) 1 Burst
I have reconsidered the situation.I guess that your master and slave would follow the rule of"an AXI interface that is receiving information can wait until it detects a VALID signal before it asserts its corresponding READY signal".Therefore, READY is not independent with VALID.In this case, my logics would fail.To solve this, we must use a latches instead of Flip-Flops to prevent the first WREADY.Regarding the read side, there are no modification.I revised my codes.Could you try them?
module AXI_W_DELAY15( CLK, ARESETN, AWVALID, // from a master AWREADY, // from a slave WVALID, // from a master WREADY, // from a slave BVALID, // from a slave BREADY, // from a master WLAST, // from a master masked_WVALID, // to a slave masked_WREADY, // to a master masked_AWREADY // to a master ); input CLK; input ARESETN; input AWVALID; input AWREADY; input WVALID; input WREADY; input BVALID; input BREADY; input WLAST; output masked_WVALID; output masked_WREADY; output masked_AWREADY; reg WADDR_DONE; reg FIRST_WDATA_MASK; reg [3:0] wcounter; wire mask_pre; wire WREADY_mask; wire WVALID_mask; reg WREADY_latch; reg WREADY_latch2; wire WREADY_latch_rst = WREADY | ~ARESETN; wire WREADY_latch_set = WADDR_DONE & WVALID; always@(posedge WREADY_latch_set or posedge WREADY_latch_rst) begin if(WREADY_latch_rst) WREADY_latch <= 0; else if(WREADY_latch_set) WREADY_latch <= 1; end wire WREADY_latch2_rst = mask_pre | ~ARESETN; wire WREADY_latch2_set = WREADY; always@(posedge WREADY_latch2_set or posedge WREADY_latch2_rst) begin if(WREADY_latch2_rst) WREADY_latch2 <= 0; else if(WREADY_latch2_set) WREADY_latch2 <= 1; end always@(posedge CLK) begin if(~ARESETN) WADDR_DONE <= 0; else if(~WADDR_DONE & AWVALID & AWREADY) WADDR_DONE <= 1; else if(BVALID & BREADY) WADDR_DONE <= 0; end always@(posedge CLK) begin if(~ARESETN) FIRST_WDATA_MASK <= 1; else if(WADDR_DONE & (wcounter==4'hf)) FIRST_WDATA_MASK <= 0; else if(wcounter==4'h0) FIRST_WDATA_MASK <= 1; end always@(posedge CLK) begin if(~ARESETN) wcounter <= 4'h0; else if(wcounter!=4'h0) wcounter <= wcounter -1 ; else if(WADDR_DONE & WVALID & WREADY_latch2 & ~(WLAST & masked_WREADY)) //!! wcounter <= 4'hf; end assign mask_pre = (wcounter != 4'h0); assign WREADY_mask = FIRST_WDATA_MASK | mask_pre; assign WVALID_mask = FIRST_WDATA_MASK | mask_pre; assign masked_WVALID = WREADY_latch | (WVALID & ~WVALID_mask); assign masked_WREADY = WREADY & ~WREADY_mask; assign masked_AWREADY = ~WADDR_DONE & AWREADY; endmodule
I am very sorry.Regarding the read, the same consideration as the write should be needed.The following is the revised code for the read.
module AXI_R_DELAY15( CLK, ARESETN, ARVALID, // from a master ARREADY, // from a slave RVALID, // from a slave RREADY, // from a master RLAST, // from a master masked_RVALID, // to a master masked_RREADY, // to a slave masked_ARVALID,// to a slave masked_ARREADY // to a master ); input CLK; input ARESETN; input ARVALID; input ARREADY; input RVALID; input RREADY; input RLAST; output masked_RVALID; output masked_RREADY; output masked_ARVALID; output masked_ARREADY; reg RADDR_DONE; reg FIRST_RDATA_MASK; reg [3:0] rcounter; reg next_rlast; reg next2_rlast; reg done_raddr; wire rmask_pre; wire RREADY_mask; wire RVALID_mask; reg RREADY_latch; reg RREADY_latch2; wire RREADY_latch_rst = RREADY | ~ARESETN; wire RREADY_latch_set = RADDR_DONE & RVALID; always@(posedge RREADY_latch_set or posedge RREADY_latch_rst) begin if(RREADY_latch_rst) RREADY_latch <= 0; else if(RREADY_latch_set) RREADY_latch <= 1; end wire RREADY_latch2_rst = rmask_pre | ~ARESETN; wire RREADY_latch2_set = RREADY; always@(posedge RREADY_latch2_set or posedge RREADY_latch2_rst) begin if(RREADY_latch2_rst) RREADY_latch2 <= 0; else if(RREADY_latch2_set) RREADY_latch2 <= 1; end always@(posedge CLK) begin if(~ARESETN) begin next_rlast <= 0; next2_rlast <= 0; done_raddr <= 0; end else begin next_rlast <= (rcounter == 4'h1); next2_rlast <= next_rlast; done_raddr <= RLAST & masked_RREADY; end end always@(posedge CLK) begin if(~ARESETN) RADDR_DONE <= 0; else if(~RADDR_DONE & ARVALID & masked_ARREADY) RADDR_DONE <= 1; else if(done_raddr & (next2_rlast & ~(RVALID & ARVALID & ARREADY))) //!!! RADDR_DONE <= 0; end always@(posedge CLK) begin if(~ARESETN) FIRST_RDATA_MASK <= 0; else if(ARVALID & masked_ARREADY) FIRST_RDATA_MASK <= 1; else if(rcounter==4'hf) FIRST_RDATA_MASK <= 0; end always@(posedge CLK) begin if(~ARESETN) rcounter <= 4'h0; else if(rcounter!=4'h0) rcounter <= rcounter -1 ; else if(RADDR_DONE & RVALID & RREADY_latch2 & ~next_rlast) //!! rcounter <= 4'hf; end assign rmask_pre = (rcounter != 4'h0); assign RREADY_mask = FIRST_RDATA_MASK | rmask_pre | next2_rlast; assign RVALID_mask = FIRST_RDATA_MASK | rmask_pre | next2_rlast; assign masked_RVALID = RREADY_latch | (RVALID & ~RVALID_mask); // RVALID for master assign masked_RREADY = RREADY & ~RREADY_mask; // RREADY for slave assign masked_ARREADY = ~RADDR_DONE & ARREADY; // this make outstanding 1 assign masked_ARVALID = ~RADDR_DONE & ARVALID; // this make outstanding 1 endmodule
I am sorry very much for many time revising.I have revised 2 parts of my codes.One is for the write and another is for the read.
(1) Write
always@(posedge CLK) begin if(~ARESETN) FIRST_WDATA_MASK <= 1; else if(WADDR_DONE & (wcounter==4'hf)) FIRST_WDATA_MASK <= 0; else if((wcounter==4'h0) & WREADY) FIRST_WDATA_MASK <= 1; end
(2) Read
always@(posedge CLK) begin if(~ARESETN) next_rlast <= 0; else if (rcounter == 4'h1) next_rlast <= 1; else if ((rcounter == 4'h0) & masked_RREADY) next_rlast <= 0; end
I will do it today and let you know. Can we talk on hangout?It will be a lot easier.
Let me explain you the code behaviour I am following:
My memory controller block is using the axi bridges to communicate with the MCB
CPU-AXI bridges(here are my channels)-MCB
Now I am not using any simulator. Rather I am using the xilinx SDK and EDK(EMBEDDED development kit). I change the hardware in EDK and then run the memory writing code in SDK and check if the data I write is being written to memory with delay or not. Note I havenot generated testbench for the my write channel or read channel as there are a lot of signals involved.
Following is my write channel code :
// File name: axi_mcb_w_channel.v
// Description:
`timescale 1ps/1ps
`default_nettype none
module axi_mcb_w_channel #
// Parameter Definitions
// Width of AXI xDATA and MCB xx_data
// Range: 32, 64, 128.
parameter integer C_DATA_WIDTH = 32,
// Width of beat counter, limits max transaction size.
// Range: 1-6 (-> 2-64 beat transactions)
parameter integer C_CNT_WIDTH = 4,
// Pipelines the wr_full signal from mcb by using
// wr_count. Does not add write latency.
parameter integer C_PL_WR_FULL = 1,
// Pipelines the wvalid and wready handshake used for
// counting. May add one cycle of latency.
parameter integer C_PL_WHANDSHAKE = 1,
// Pipelines the intermodule signal w_complete. May add
// 1 cycle of latency.
parameter integer C_PL_W_COMPLETE = 1
// Port Declarations
input wire clk ,
input wire reset ,
input wire [C_DATA_WIDTH-1:0] wdata,
input wire [C_DATA_WIDTH/8-1:0] wstrb,
input wire wlast,
input wire wvalid,
output wire wready,
output wire wr_en,
output wire [C_DATA_WIDTH/8-1:0] wr_mask,
output wire [C_DATA_WIDTH-1:0] wr_data,
input wire wr_full,
input wire wr_empty,
input wire [6:0] wr_count,
input wire wr_underrun,
input wire wr_error,
input wire calib_done,
output wire w_complete,
input wire w_trans_cnt_full
// Local parameters
localparam integer P_MCB_FULL_CNT = 64;
// Wire and register declarations
wire whandshake;
reg [C_CNT_WIDTH-1:0] cnt;
reg subburst_last;
wire w_complete_ns;
wire w_complete_i;
wire wready_i;
wire wlast_i;
wire whandshake_i;
// BEGIN RTL
assign wready = wready_i;
assign wr_en = whandshake;
assign wr_mask = ~wstrb;
assign wr_data = wdata;
assign whandshake = wvalid & wready;
generate
if (C_PL_WR_FULL) begin : PL_WR_FULL
reg [6:0] wr_count_d1;
wire wr_afull_ns;
reg wready_r;
// Calculate almost full from wr_count instead of using wr_full for timing
// closure
always @(posedge clk) begin
wr_count_d1 <= wr_count;
assign wr_afull_ns = (wr_count_d1 > (P_MCB_FULL_CNT-3));
if (reset) begin
wready_r <= 1'b0;
end else begin
wready_r <= ~wr_afull_ns & calib_done & ~w_trans_cnt_full;
assign wready_i = wready_r;
else
begin : NO_PL_WR_FULL
assign wready_i = ~wr_full & calib_done & ~w_trans_cnt_full;
endgenerate
if (C_PL_WHANDSHAKE) begin : PL_WHANDSHAKE
reg wlast_d1;
reg whandshake_d1;
// Count the number of beats we have
// Use delayed values of the incoming signals for better timing
wlast_d1 <= wlast;
whandshake_d1 <= whandshake;
assign wlast_i = wlast_d1;
assign whandshake_i = whandshake_d1;
else begin : NO_PL_WHANDSHAKE
assign wlast_i = wlast;
assign whandshake_i = whandshake;
if (w_complete_ns | reset) begin
cnt <= {C_CNT_WIDTH{1'b1}};
end else if (whandshake_i) begin
cnt <= cnt - 1'b1;
// Determines have reached a subburst boundary
if (reset | w_complete_ns) begin
subburst_last <= 1'b0;
end else if ((cnt == {{C_CNT_WIDTH-1{1'b0}},1'b1}) & whandshake_i) begin
subburst_last <= 1'b1;
assign w_complete_ns = whandshake_i & (wlast_i | subburst_last);
if (C_PL_W_COMPLETE) begin : PL_W_COMPLETE
reg w_complete_r;
// latch the output of w_complete
w_complete_r <= w_complete_ns;
assign w_complete_i = w_complete_r;
else begin : NO_PL_W_COMPLETE
assign w_complete_i = w_complete_ns;
assign w_complete = w_complete_i;
endmodule
`default_nettype wire
I want not to talk on hangout, because I will not support until you will succeed.I can only give you hints.I did my best by proposing an example which can work well in a certain environmentNow, I would like to finish the conversation.
By the way, if you have the AXI bridge, how about adding the following logics into the bridge?As the wready can be generated independently with wvalid, any latches will not be needed.
assign wtimer_trigger = wvalid & wready_i;assign wready = (wtimer == 5'h1) & wready_i;
always @(posedge clk) beginif(reset) wtimer <= 5'h0;else if(wtime != 5'h1) wtimer <= wrimer - 1;else if(wtimer_trigger & (wtimer == 5'h0)) wtimer <= 5'h10;else if(wready) wtimer <= 5'h0;end
Thank you so much for all the suggestions you have provided me.. You have really brought me this far. I have tried the write (with latches ) it does not seem to work. Some last doubts to end the conversation. Please let me if your write channel is similar to mine and the test bench you have used to test it. I have tried the bridge suggestion as well. But that does not delay my data.
I cannot judge whether your axi_mcb_w_channel logic would be correct or not.It seems to have a lot of strange parts for me.Honestry speaking, I wonder why my proposal for the bridge did not work.
Is your data modification done between the bridge and the slave?My assumption is that it would be done between CPU and the bridge.
Yes sir I have made the modifications between bridge and the slave as I do not have access to the CPU part of the code. You can have a look at the attachment(axi_mcb_w_channel.v) to see where I have made the changes. Also I have attached axi bridge(axi_mcb.v). Sir, can you please tell me which particular simulator have you used.
I am working on the latch code sent by you.
I am afraid that you would insert the delay logic into the axi_mcb_{aw,w,b}_channel_0. It would be to very complex and difficult.
I recommend to put my logic on between the register slice and the axi_mcb_{aw,w,b}_channel_0.
