CortexA8 L2 data loss
Hi at all!
I'm working with TI DM3730 (CortexA8 inside) and an external mobile DDR-SDRAM.
The startup initialize MMU, L1 Cache and L2 Cache and Flow Prediction.
Tests with about 256MiB of data show some data loss when L2 Cache is enabled.
If L2 is disabled and only L1 I and D Cache is enabled, the data tests work properly.
Here is my MMU-Setting:
Device-Registers: AP = 3, mode = 2, TEX = 0, C = 0, B = 0
internal RAM: AP = 3, TEX  = 0, C = 1, B = 0
external RAM: AP = 3, TEX = 0, C = 1, B = 0
all areas are mapped to domain 0 and all domains are set to client mode.
If the MMU-Settings for external RAM are set to TEX = 0, C = 0 and B = 0 (disable caching for external RAM), there is also no data loss and all work fine.
Anyone an idea?
Here is the complete code of initialization:
  *   disable 'Instruction Cache' , 'Flow Prediction'
  *   disable 'Data Cache' , 'MMU'
  *   enable  'Alignment check'
  mrc     p15, 0, r0, c1, c0, 1       // read auxiliary control register
  bic     r0, r0, #(0x1 << 1)         // disable L2-Cache
  mcr     p15, 0, r0, c1, c0, 1       // write back
  mrc     p15, 0, r0, c1, c0, 0       // read control register
  bic     r0, r0, #(0x1 << 0)         // disable MMU
  orr     r0, r0, #(0x1 << 1)         // enable Strict alignment fault checking
  bic     r0, r0, #(0x1 << 2)         // disable D-Cache
  bic     r0, r0, #(0x1 << 11)        // disable Flow prediction
  bic     r0, r0, #(0x1 << 12)        // disable I-Cache
  bic     r0, r0, #(0x1 << 13)        // Use Normal exception vector
  mcr     p15, 0, r0, c1, c0, 0       // write back
  *   set 'Vectore Base Address'
  ldr     r0, =dm3730_initVector
  mcr     p15, 0, r0, c12, c0, 0
  *   Invalidate 'Translation Table Base' (TLB)
  *   Invalidate 'Instruction Cache' und
  *               lösche 'branch target cache'
  mov     r0, #0
  mcr     p15, 0, r0, c8, c7, 0       // Invalidate Inst-TLB und Data-TLB
  mcr     p15, 0, r0, c7, c5, 0       // Invalidate all instruction caches and flushes branch target cache
  *   Cache Invalidation code ->
  *    github.com/.../startup.s
  mrc     p15, 1, r0, c0, c0, 1                   // Read CLIDR
  ands    r3, r0, #0x07000000                     // Extract coherency level
  mov     r3, r3, lsr #23                         // Total cache levels << 1
  beq     processor_FirstBootEntry_cacheExit      // If 0, no need to clean
  mov     r8, #0                                  // R8 holds current cache level << 1
processor_FirstBootEntry_cacheLoop1:
  add     r2, r8, r8, lsr #1                      // R2 holds cache "Set" position
  mov     r1, r0, lsr r2                          // Bottom 3 bits are the Cache-type for this level
  and     r1, r1, #7                              // Isolate those lower 3 bits
  cmp     r1, #2
  blt     processor_FirstBootEntry_cacheSkip      // No cache or only instruction cache at this level
  mcr     p15, 2, r8, c0, c0, 0                   // Write the Cache Size selection register
  ISB                                             // ISB to sync the change to the CacheSizeID reg
  mrc     p15, 1, r1, c0, c0, 0                   // Reads current Cache Size ID register
  and     r2, r1, #7                              // Extract the line length field
  add     r2, r2, #4                              // Add 4 for the line length offset (log2 16 bytes)
  movw    r4, #0x3ff
  ands    r4, r4, r1, LSR #3                      // R4 is the max number on the way size (right aligned)
  clz     r5, r4                                  // R5 is the bit position of the way size increment
  movw    r6, #0x7FFF
  ands    r6, r6, r1, LSR #13                     // R6 is the max number of the index size (right aligned)
processor_FirstBootEntry_cacheLoop2:
  mov     r7, r4                                  // R7 working copy of the max way size (right aligned)
processor_FirstBootEntry_cacheLoop3:
  orr     r1, r8, r7, lsl r5                      // Factor in the Way number and cache number into R1
  orr     r1, r1, r6, lsl r2                      // Factor in the Set number
  mcr     p15, 0, r1, c7, c6, 2                   // Invalidate by Set/Way
  subs    r7, r7, #1                              // Decrement the Way number
  bge     processor_FirstBootEntry_cacheLoop3
  subs    r6, r6, #1                              // Decrement the Set number
  bge     processor_FirstBootEntry_cacheLoop2
processor_FirstBootEntry_cacheSkip:
  add     r8, r8, #2                              // increment the cache number
  cmp     r3, r8
  bgt     processor_FirstBootEntry_cacheLoop1
processor_FirstBootEntry_cacheExit:
  DSB
   *   MMU Settings
   // Hier Code kopieren vom Cache-Handling
   /* invalidate TLB */
   mov     r0, #0
   mcr     p15, 0, r0, c8, c7, 0       // set TLB for instruction and data invalid
   /* TLB Addr setzen */
   mov     r0, #0
   mcr     p15, 0, r0, c2, c0, 2       // set Table-Base-Control register to 0
   ldr     r0, =mmuL1PageTable         // load addr of MMU-L1-PageTable
   mcr     p15, 0, r0, c2, c0, 0       // set addr of MMU-L1-PageTable
    *   Setup domain control register -
    *   Enable all domains to client mode
  movw    r0, #0x5555             // setl all domains to client mode
  movt    r0, #0x5555
  mcr     p15, 0, r0, c3, c0, 0   // write domain control register
    *   Write L2 Cache Auxiliary Control Register
    mov     r0, #0
    mcr     p15, 1, r0, c9, c0, 2
#ifdef __ARM_NEON__
    *   Enable NEON/VFP
    mrc     p15, 0, r0, c1, c0, 2       // Read CP Access register
  orr     r0, r0, #(0xF << 20)        // Enable full access to NEON/VFP (Coprocessors 10 and 11)
  mcr     p15, 0, r0, c1, c0, 2       // Write CP Access register
  mov     r0, #0x40000000             // Switch on the VFP and NEON hardware
  vmsr    FPEXC, r0                   // Write FPEXC register, EN bit set
#endif
    *   Enable MMU
    mrc     p15, 0, r0, c1, c0, 0       // read Control Register
    orr     r0, r0, #(0x1 << 0)         // enable MMU
    *   Enable L2-Caches
    mrc     p15, 0, r0, c1, c0, 1       // Lese Auxiliary Control Register
    orr     r0, r0, #(0x1 << 1)         // enable L2-Cache
    *   Enable Caches
    orr     r0, r0, #(0x1 << 12)        // enable I-Cache
    orr     r0, r0, #(0x1 << 2)         // enable D-Cache
    orr     r0, r0, #(0x1 << 11)        // enable Flow prediction
