Non aligned access in arm v7 going into exception
typedef struct __attribute__((__packed__))
uint8_t    op_code;
uint8_t    flags;
uint32_t   logical_block_addr;
uint8_t    group_num;
uint16_t   tx_length;
uint8_t    control;
} SCSI_READ10_t;
when I am assigning some value to tx_length core is showing some exception. Is the assembly of   tx_length assignment  compiler is putting strh/ldrh(half-byte) instruction throwing error its not 2 byte aligned . But not aligned accesses are enabled. So my question is : -
Q1. Can I access not aligned memory with strh/ldrh (suppose addr :- 0xxxx37) if non aligned accesses are enabled for core ?
Q2. Do compiler take care of these no aligned access and will convert not aligned half word into two  1 byte accesses ?
  • Generally speaking, enable data caching of that memory space is a good solution.
    As Yasuhiko showed, GCC may refine the assembly code for unaligned access.
    But I think it may rely on GCC version or build options and may impact performance.
    So my suggestion is:
    If you can, enable data cache and map that space to cacheable.
    If you cannot enable cache for that space:
    1 Search GCC documents for unaligned access conversion
    2 Byte copy this packed field to a buffered unpacked structure if it doesn't update frequently.
