Is the 'S' necessary in the asm code?
Before I write some Cortex A8 assembly code, I review some disassembly code of a small C program. In the following snippet, I don't understand the necessity of 'S' in ADDS. In fact, I don't see the usefulness of the whole line of
ADDS     R0, R0, #0
Is this compiler not very efficient?
I would like to have your opinion on the disassembly code.
typedef unsigned long long Uint64;
typedef int     Int32;
typedef unsigned int           Uint32;
40301660:   F1AD0D10 SUB.W           R13, R13, #16
40301664:   9000     STR             R0, [SP]
153           x = 0x76CF41F2 - ( d << 1 );                    /* initialized value x(0) */
40301666:   9900     LDR             R1, [SP]
40301668:   486F     LDR             R0, $C$CON3
4030166a:   EBA00041 SUB.W           R0, R0, R1, LSL #1
4030166e:   9001     STR             R0, [SP, #4]
156           tmp = ( Uint32 )( ( ( Uint64 )x * ( Uint64 )d ) >> 32 );
40301670:   9801     LDR             R0, [SP, #4]
40301672:   9900     LDR             R1, [SP]
40301674:   FBA11000 UMULL.W         R1, R0, R1, R0
40301678:   1C00     ADDS            R0, R0, #0
4030167a:   9002     STR             R0, [SP, #8]
Now, I have a following question from the beginning. In the above 32-bit * 32-bit, the result is in R0:R1. When I need the high 32-bit (R0), a better way is to round the MSB of R1 to the LSB of R0. I do not want a strict symmetric rounding here. That is, we consider only a simple R1+0x8000,0000. The above addition carry bit is added to R0. I am still new to ARM A8 instructions. I find that there are quite a few instructions needed to the rounding.
I would like to know whether you have a good trick to get the result very efficiently.
Thanks,
