Hi All,
1) 1st master is doing locked write transfer to 'X location after that, Can 2nd master initiate a read normal transfer for 'Y address in same slave? . And still unlocked transfer is not initiated by the 1st master?.
2) Locked transfer is for Bus channel or specific Slave region?
Regards,
Deepak
From the AMBA AXI spec:
When the ARLOCK[1:0] or AWLOCK[1:0] signals for a transaction show that it is a locked transfer then the interconnect must ensure that only that master is allowed access to the slave region until an unlocked transfer from the same master completes. The arbiter within the interconnect is used to enforce this restriction.
Hi Martin,
Thank you, I have got more clear about LOCKED access. I have ohter questions about LOCKED transfer.
deepak
