Hi, we are using arm cortex-a9 booting from spansion s25fl256. We are confused why the spi driver forces to limits flash size to 0x1000000 (16M). It's normal when first bring up and into linux. However, we find the uboot is broken or overrided and can't boot after reset. If anyone meet the same issue or have any ideas? Thanks for your suggestion.
Can you provide more information about your SPI controller (or SoC)? Where did you get the SPI driver?
Hi, David,
We use bcm625xx serial and use bcm947xx spi driver. Because our board config cpu in 3-byte mode and limit size into 16M, so it needs to do something to make it works.
