Hi experts,
i am trying wakeup the secondary CPU core in bootloader, i am able to do this through a trusted firmware. The problem comes after wakeup!
Once the cpu is up it will be in EL-2 mode and it executes a predefined function, in which i will load the stack pointer(SP) with a valid address and transfer the control to a function written in c-code. once the controls is transferred it is not executing the any of further functions. Are there any additional settings which need to be done before we pass the control to actual function?
below is the code which is executed by the secondary cpu.
.global reset_handler_smp reset_handler_smp: ldr x3, =( svc_secondary_stack ) /* stack base ptr */ mrs x1, mpidr_el1 /* read mpidr reg */ and x0, x1, #0xf /* cpuid =mpidr[3:0] */ mov x2, #STACK_SIZE /* stack size */ mul x0, x0, x2 add x3, x3, x0 /* x3 - per cpu stack */ bic sp, x3, #7 /* 8bit aligned stack */ bl _secondary_cpu_entry looop: b looop
can some one please help me
A few things to note:
In terms of helping you narrow down the exact issue, the most important information to provide will be the value of the ESR_ELx register (probably ESR_EL2 from what you've said) when you take the exception.
Ash.
Hi Mr. Ash,
Thanks for the inputs.
AArch64 uses a "Full Descending" stackThe "full" means that the SP points to the most-recently-pushed item (unlike an "empty" stack, where SP points to the next empty slot for an item to be pushed to). The "descending" means that the SP is decremented when pushing items, and incremented when popping (unlike an "ascending" stack, which is the reverse)So, your code for initialising the SP is wrong, because CPU #0's SP will point to the base of your stack, and then pushing anything to the stack will take you outside of your stack region. To fix this, you should be loading the limit of the stack into X3, and then subtracting the multiple of (CPUID * STACK_SIZE) from this limit.
You are aligning your stack to 8-bytes, but the AAPCS (ARM AArch64 Procedure Call Standard) mandates that the SP be 16-byte aligned
Yes 16bit alignment was the mistake done it's been corrected. Now there is an exception caused by an functions where the ESR_EL value is 0x96000035.
Did you mean to put a BL to _secondary_cpu_entry, rather than just a B?I wouldn't expect the secondary CPUs to ever return to this reset handler code, so a BL is probably wrong? And you actually just want a B
I agree with you just B was sufficient as i mentioned earlier it was copied code snippet so it just remained thanks for pointing out.
Thanks,
Harish.
Thanks for the help Mr.Ash Wilding
