Hi, I make a software for Cortex-A9 and Cortex-M4 (both uni-processor system).
Question.
Is 64bit-aligned STRD(64bit memory access) atomic ?
(I know tha It is not atomic, but i don't know behavior.)
For example:
LDR R2,=buff
mov R0, #1
mov R1, #2
STRD R0, R1, [R2]
mov R0, #3
mov R1, #4
STRD R0, R1, [R2] <- interrupt occerd
handler:
LDR R0, R1, [R2] <--- ???
Is[R0,R1] == [#3, #2] may?
If it is, require disable-interrupt between STRD?
Basically the answer for the question would be an implementation dependence.Therefore the situation would be different between Cortex-A9 and Cortex-M4.
The instruction cycles of Cortex-A9 STRD is 1 and it cannot be aborted-restarted by an interrupt.
But there is no guarantee for the fact.
Regarding Cortex-M4, the execution logic of STRD would be the same as STM and it can be aborted-restarted by abn interrupt.
However, in Cortex-M4 case, the interrupt abort of the multi-cycle instruction can be disabled by ACTLR (0xE000E008).
And then, I think Cortex-M4 STRD would become atomic.
Best regards,
Yasuhiko Koumoto.
Thanks for answer.
"the execution logic of STRD would be the same as STM"
Really?
STM instruction use ICI bit for retry sequence.
But STRD not use ICI bit.
On Cortex-v7m manual, "LDM, LDMDB, STM, STMDB, POP, and PUSH" use ICT bit, STRD/LDRD not.
How do retry STRD?
regarding your question, I don't know and it is just a guess.
Is it so important?
However, STRD can be produced as a form of STM instruction according to a compiler convenience.
In this case, ICI bit would be used.
I think the retry sequence of STRD would be the same as STM retry in IT block.
That is, it is to retry from the beginning.
If you want STRD not to be interrupted, you may not use STRD but use two STRs.
Best regards.
I need a atomic 'long long' access.
for A9/M4, GCC may output 'LDRD/STRD instruction' for long long.
and typically, long long variable is aligned by 8bytes.
But, if LDRD/STRD is interrupted, must be intterupt-disable for ATOMIC-access?
why don't you use STM and ACTLR, disabling the interrupt abort of STM?
It enables more than 64 bit atomic write.
OK
I consider.
Thank you.
