I am trying to setup timer at EL1 level and not able to write to CNTP_CVAL register.
I would like to know what is the meaning of "Config-RW" ? It means can be configured ? eg. to be accessed from (NS) EL1 mode ?
If so what/how to configure to achieve it ?
Thanks,
Config-RW means it's RW based on the configuration(i.e. it can be RW if required
configuration is enabled, not accessible or trapped otherwise).
Please read Traps&Enables section under G6.5.8 CNTP_CVAL, Counter-timer Physical
Timer CompareValue register in ARMv8 ARM ARM or similar section in the document
you are referring.
Regards,
Sudeep
