At first, sorry to my fool English.
I want to know how to set to inner or outer shareable attribute on page table entry using TEX, C, B and S bit (without TEX remap).
I knew if i use TEX remap, the PRRR NOT bit used to set to outer or inner but i didn't find explain in without TEX remap.
Thanks.
Hi levi,
The quick answer is that you can just set the TEX encoding to reflect the shareability and use the "S" bit for certain encodings, you just can't set inner/outer shareability separately - but certain TEX values do infer shareability for both regions. This is documented in B3.8.2 of the ARMv7-AR ARM ("Short-descriptor format memory region attributes, without TEX remap."
Ta,
Matt
Thanks a lot your answer. But i have still a question.. when i see ur mentioned part, i can find this.
i think these bit define cash policy about inner/outer. but is it related also to SHAREABLITIY??
for example when TEX 000, B 1 C 1 ===> Cuz it defind Outer and Inner policy of cash, it also implies inner/outer shareability.
and when using last one (TBX : 1BB , C:A, B:A), Could i set sharability of inner/outer with cashability of that?
It's the right-hand column - it's either (Inner AND Outer) Shareable, (Inner AND Outer) Non-Shareable, or controlled by the S bit (one bit controls both Inner AND Outer shareability).
