Pseudocode for saturation (Oh no, not again)
In some instruction descriptions there are calls to SignedSatQ (directly or indirectly).
The pseudocode for SignedSatQ:
(bits(N), boolean) SignedSatQ(integer i, integer N)
if i > 2^(N-1) - 1 then
result = 2^(N-1) - 1; saturated = TRUE;
elsif i < -(2^(N-1)) then
result = -(2^(N-1)); saturated = TRUE;
else
result = i; saturated = FALSE;
return (result<N-1:0>, saturated);
What's the idea with 'result<N-1:0>' in the return (shifting the result one bit left)?
  • In pseudocode integers and bitstrings are different things. Integers are arbitrary precision and bitstrings are, well, strings of bits...
    In this function, "result" is an integer. To convert an integer to a bitstring, you can apply the bit splice operation. Hence "result<N-1:0>" is just converting the integer to an N-bit string (i.e. extracting bits N-1 to 0). It's not shifting the result.
