I was using following method to read clock in cortex-a15:
static void readticks(unsigned int *result)
struct timeval t;
unsigned int cc;
if (!enabled) {
// program the performance-counter control-register:
asm volatile("mcr p15, 0, %0, c9, c12, 0" :: "r"(17));
//enable all counters
asm volatile("mcr p15, 0, %0, c9, c12, 1" :: "r"(0x8000000f));
//Clear overflow.
asm volatile("mcr p15, 0, %0, c9, c12, 3" :: "r"(0x8000000f));
enabled = 1;
asm volatile("mrc p15, 0, %0, c9, c13, 0" : "=r"(cc));
gettimeofday(&t,(struct timezone *) 0);
result[0] = cc;
result[1] = t.tv_usec;
result[2] = t.tv_sec;
And final performance looks like:
before = readticks()
foo()
after = readticks()
clock_cycles = after - before.
I want to use same logic in cortex-A53, ARM64 (not aarch32).
I have tried this after following online portals:
/* All counters, including PMCCNTR_EL0, are disabled/enabled */
#define QUADD_ARMV8_PMCR_E (1 << 0)
/* Reset all event counters, not including PMCCNTR_EL0, to 0
#define QUADD_ARMV8_PMCR_P (1 << 1)
/* Reset PMCCNTR_EL0 to 0 */
#define QUADD_ARMV8_PMCR_C (1 << 2)
/* Clock divider: PMCCNTR_EL0 counts every clock cycle/every 64 clock cycles */
#define QUADD_ARMV8_PMCR_D (1 << 3)
/* Export of events is disabled/enabled */
#define QUADD_ARMV8_PMCR_X (1 << 4)
/* Disable cycle counter, PMCCNTR_EL0 when event counting is prohibited */
#define QUADD_ARMV8_PMCR_DP (1 << 5)
/* Long cycle count enable */
#define QUADD_ARMV8_PMCR_LC (1 << 6)
static inline unsigned int armv8_pmu_pmcr_read(void)
unsigned int val;
/* Read Performance Monitors Control Register */
asm volatile("mrs %0, pmcr_el0" : "=r" (val));
return val;
static inline void armv8_pmu_pmcr_write(unsigned int val)
asm volatile("msr pmcr_el0, %0" : :
"r" (val & QUADD_ARMV8_PMCR_WR_MASK));
static void enable_all_counters(void)
/* Enable all counters */
val = armv8_pmu_pmcr_read();
val |= QUADD_ARMV8_PMCR_E | QUADD_ARMV8_PMCR_X;
armv8_pmu_pmcr_write(val);
static void reset_all_counters(void)
val |= QUADD_ARMV8_PMCR_P | QUADD_ARMV8_PMCR_C;
reset_all_counters();
enable_all_counters();
cc = armv8_pmu_pmcr_read();
But nothing is working and i am gettin "illegal instruction" error. Can anyone help me to change the above code?
Thanks,
RV
This is an EL0 (userspace) app? If so it's configurable whether the PMU can be accessed at EL0. Controlled by PMUSERENR_EL0. It's possible you configured the equivalent (PMUSERENR) on the Cortex-A15 platform, but not on this one.
Your code snippet doesn't include an ISB instruction. Changes to context (e.g. enabling the PMU) is not guaranteed to take effect until a context synchronizing event. If you have access to DS-5, it includes some example bare metal PMU code with the required ISBs.
One other note, the PMU measure cycles rather than time. I'm guessing you already know that, but I thought it worth mentioning.
@Chris Shore
mweidmann
@sujathalakshmi.k
Please help.
Yes, its an EL0 app. I am trying to benchmark some algorithms for cortex-a53 and I need clock cycles as benchmark not time. I dont have access to DS-5.
So I got this from manual that PMCR_EL0, which is 32 bit reg, can be used as performance monitor directly in aarch64. I have changed the readtick function simple like this:
//reset all counters
asm volatile("msr pmcr_el0, %0" : : "r" (17));
asm volatile("msr pmcr_el0, %0" : : "r" (0x8000000f));
asm volatile("mrs %0, pmcr_el0" : "=r" (cc));
I think its good so far but the actual problem is to use Hyp mode.
I was using this small driver in Cortex-A15 (explaned here: http://bench.cr.yp.to/cpucycles/netwalker.html):
#include <linux/module.h>
#include <linux/kernel.h>
MODULE_LICENSE("Dual BSD/GPL");
#define DEVICE_NAME "enableccnt"
static int enableccnt_init(void)
printk(KERN_INFO DEVICE_NAME " starting\n");
asm volatile("mcr p15, 0, %0, c9, c14, 0" :: "r"(1)); // Write to HVBAR characteristic register.
return 0;
static void enableccnt_exit(void)
asm volatile("mcr p15, 0, %0, c9, c14, 0" :: "r"(0));
printk(KERN_INFO DEVICE_NAME " stopping\n");
module_init(enableccnt_init);
module_exit(enableccnt_exit);
So, from the technical referece manual of cortex-a53, I got VBAR_EL2 characteristics register equivalent to HVBAR in aarch32. I modified the driver as
asm volatile("MSR VBAR_EL2, %0" :: "r"(1)); // Write to VBAR_EL2 characteristic register.
asm volatile("MSR VBAR_EL2, %0" :: "r"(0));
When I am inserting this into kernel. Its giving "segmentation fault". attached is the picture of dmeg command .
I am not sure that whether I should set some vlaues to "Hyp Debug Control Register"?
And
I am getting whether I should use isb instructions as it was working as it is in cortex-a15?
I appreciate any help.
