How many Redistributors needed if I using GIC600 with Cortex-A65AE which is SMT core?
Hi, all
How many Redistributors needed if I using GIC600AE with Cortex-A65AE which is SMT(simultaneous multithreading) core?
I found PE(Processing Element) means a instance of thread-execution unit so PE is double of Core numbers from the Cortex-A65AE because it is dual-threaded core.
And GIC600AE said Redistributor of GIC600AE has to be placed with same numbers per PE.
For example, If I have two of Cortex-A65AE with Split-mode capable system, then I need four Redistributors (double of core numbers) and each Redistributors should be connected with each PEs in Cortex-A65AE, right?
  • It's said in the GIC600 trm, "The Redistributor maintains the Private Peripheral Interrupts (PPIs) and Software Generated
    Interrupts (SGIs) for a particular set of cores". A single redistributor can serve a cluster.
  • For example, If I have two of Cortex-A65AE with Split-mode capable system, then I need four Redistributors (double of core numbers) and each Redistributors should be connected with each PEs in Cortex-A65AE, right?
    That's correct.
    The distinction between a single threaded core and a thread of multi-threaded core is really micro-architecture/implementation detail.  Architecturally, what the GIC cares about is things that can be targets for interrupts.  That's PE, each identified by a different affinity value.
