How to know L2 cache ECC single / multiple bit error separately ?
For Cortex A53, I can't find separate bit definition for L2 ECC single and multiple bit error in L2MERRSR....
1. bit 31 for L2MERRSR (L2MERRSR_EL1) is for L2 cache ECC multiple bit error, correct ?
2. Which register/bit can I know whether L2 cache ECC single bit error occurs ?
Thanks,
Anderson
  • L2 Cache uses SECDED (single error correction, double error detection), so there is a good chance, that a single bit error won't be counted.
    Edit: The manual says:
    "Error injection on the L2 data RAMs is enabled by setting the L2ACTLR.L2DEIEN bit. While
    this bit is set, double-bit errors are injected on all writes to the L2 cache data RAMs. "
    So,since one cannot test single bit errors, it is likely they are corrected w/o notice.
