Hi Experts,
As the general discussions seen in the community, it would be great if there is a general guidelines on the list of criteria or guidelines involved in the selection of Cortex A/R/M series Processors ?
Rather than application specific some other factors like power consumption, memory usage, size constraints and typical examples on various commercial products which employs these processors ?
Also it will be more artistic if there is a single chart for each family explaining these variances.
Regards,
Techguyz
It would be great if someone address this !!
Hi pravinchanm
I'm not understand what exactly you want here ?
My "remember" solution (work in general)
Regards
Thanks Jerome.
I do look for a derivation to meet the requirements with respect to the MIPS/Power and other parameters on assumed percentage of latency.
with regards to operations per energy consumption of the CPU I learned that parallel processors perform better. So may be an energy efficient but secure system featuring an embedded client with an Cortex M4 is the best solution. Costly calculations may be done on a server..
The FPU of the M4 is may be not needed but some computing performance for the encryption.
