Hi Experts,
In the Memory Protection Unit,
what is the difference between Sub regions and the Overlapping regions ?
What is the typical use case of the MPU and how it helps in building a quality software ?
Regards,
Techguyz
Overlapping regions:
Each region is defined by a base address, a size and some attributes.
If you define multiple regions, it is possible some might overlap. For example:
Region A: Covers 1MB starting at 0x0
Region B: Covers 4KB starting 0x10000
The address range 0x10000-0x10FFF is now covered by both A and B. So which attributes should it use? The overlapping region rules in the PMSA describes how this is resolved.
Sub-regions:
Each region (as long as it's at least 256 bytes) is sub-divided into 8 sub-regions. With an enable bit per sub-region. Effectively allowing you to "poke a hole" in a region. The corresponding addresses are not treated as part of the region. They will either pick-up the attributes of an overlapping region (if there is one), or use the defaults.
Allowing overlapping and sub-regions gives you flexibility, and can in many cases reduce the total number of regions you need to define.
Thanks for the reply martin.
