I.MX8.MINI(CORTEX A53) Unable to complete the conversion of exception level from EL2 to EL1
Unable to complete the conversion of exception level from EL2 to EL1,After executing ERET, the CPU hangs up. I don't know why. Here's the code:
mrs x9, CurrentEL
// Check the current exception level.
cmp x9, CURRENTEL_EL1
beq .Ltarget
cmp x9, CURRENTEL_EL2
beq .Lin_el2
// Otherwise, we are in EL3.
// Set EL2 to 64bit and enable the HVC instruction.
mrs x9, scr_el3
mov x10, SCR_EL3_NS | SCR_EL3_HCE | SCR_EL3_RW
orr x9, x9, x10
msr scr_el3, x9
// Set the return address and exception level.
adr x9, .Ltarget
msr elr_el3, x9
mov x9, SPSR_ELX_DAIF | SPSR_ELX_EL1H
msr spsr_el3, x9
.Lin_el2:
// Disable EL1 timer traps and the timer offset.
mrs x9, cnthctl_el2
orr x9, x9, CNTHCTL_EL2_EL1PCEN | CNTHCTL_EL2_EL1PCTEN
msr cnthctl_el2, x9
msr cntvoff_el2, xzr
// Disable stage 2 translations.
msr vttbr_el2, xzr
// Disable EL2 coprocessor traps.
mov x9, CPTR_EL2_RES1
msr cptr_el2, x9
// Disable EL1 FPU traps.
mov x9, CPACR_EL1_FPEN
msr cpacr_el1, x9
// Check whether the GIC system registers are supported.
mrs x9, id_aa64pfr0_el1
and x9, x9, ID_AA64PFR0_EL1_GIC
cbz x9, .Lno_gic_sr /* */
// Enable the GIC system registers in EL2, and allow their use in EL1.
mrs x9, ICC_SRE_EL2
mov x10, ICC_SRE_EL2_ENABLE | ICC_SRE_EL2_SRE
orr x9, x9, x10
msr ICC_SRE_EL2, x9
// Disable the GIC virtual CPU interface.
msr ICH_HCR_EL2, xzr
.Lno_gic_sr:
// Set EL1 to 64bit.
mov x9, HCR_EL2_RW
msr hcr_el2, x9 /* */
adr x9, .Ltarget
msr elr_el2, x9
msr spsr_el2, x9 /* */
isb
eret
.Ltarget:
ret
I want to know if it's a code problem, or other problems, and how to transfer from EL2 to EL1!
