how to use aese and aesd instruction in aarch64
Hi all,
I want to use aes instructions for implementing AES-128 ECB algorithm. Such implementation contains several aes instructions (e.g., the aese, aesmc, aesd, aesimc).
I implement the prototype of AES encryption and AES decryption. In decryption, I use the aesimc to replace the aesmc instruction, then use aesd to replace the aese. Moreover, I select the key in decryption is the same as that in encryption.
To verify it, I encrypt one 128-bit plaintext, then decrypt it. However the result of my decryption is not the same as my plaintext.
I check my codes and find the reason: the output of one aese-aesd round will be different from the input.
Specifically, my codes are listed as follows:
ld1 {v0.16b}, [x0]  //x0 stores the plaintext
aese v0.16b, v1.16b  //v1 stores the key, and the result of aese is stored in v0
aesd v0.16b v1.16b  //v1 stores the key, and the result of aesd is stored in v0
//fetch the value in v0 and compare it with the plaintext stored in x0.
Can someone helps me?
