ACE protocol Acknowledgement signal
Why even in after load and store operation RACK signal is given as an acknowledgement? why not WACK in case of store operations?
  • RACK and WACK correspond to transactions completing on the AR and AW channels respectively.  AR requests require the ACE manager to give a RACK, and AW requests require the ACE manager to give a WACK.
    For ACE managers, coherent stores are typically* performed by the ACE manager obtaining a Unique copy of the cache line within its cache.  This is generally performed using an operation on the AR channel, and so a RACK response is given.
    * The exceptions here are Write[Line]Uniques and memory update operations which are issued on the AW channel and so would result in a WACK response being given.
