I just got a raspberry pi 2 and I'd like to play with Trustzone.
People on the Raspberry forum http://www.raspberrypi.org/forums/viewtopic.php?p=697474#p697474 explained me how to
get my hand on the boot of the 4 core A7 CPU, and I managed to boot my kernel (at 0x8000) in monitor mode, thus I can
do pretty much whatever I want (by replacing the 'movs pc, lr' by a 'bx lr' at the end of the secure_monitor, cf line 50 at http://pastebin.com/rgGgBuTN).
However, I'm trying to understand the code they gave me, and I noticed some really weird situation:
- If I replace the 'smc #0' instruction line 80 with a 'cps #MON_MODE' followed by the body of the _secure_monitor handler, the boot hangs (see http://pastebin.com/TngpAmt1)
I thought that 'smc' only updated cpsr, sprs and lr. Is an explicit 'smc' instruction is required to successfully initialize a cortex A7 ?
- In the _secure_monitor, if I do not set SCR.NS to 1, I expected to stay in secure mode, but the boot hangs
- However, once I reached my code (0x8000), I can change SCR.NS any way I want.
I'm really not familiar with CPU initialization and SMP context, any help to understand what is happening is welcome !
Best,
Vincent
Hi vsiles,
It helps to dig into what the code in the _secure_monitor handler actually does - I took this paste from the original code provided by the RPi folks in your post:
The "orr" on line 4 of the paste above is setting the bottom bit in a temporary register, which is intended to go into the SCR (line 11).
There seems to be a little confusion on what SCR.NS actually does - it is prudent to note that the bit does not actually change the security state of the processor (Monitor mode is always a Secure state), but it does provide a way to access what the ARM Architecture Reference Manual refers to as the Secure Banked CP15 Registers and their Non-Secure Banked CP15 Registers equivalents. In this case the moment the SCR register is written at line 11, the intent of the code is that you want to access the Non-Secure copies. If we proceed to line 14 we see that it is intending to write to the HVBAR. The HVBAR is a special register in that it isn't part of the Secure Banked CP15 Registers and is only present in the Non-Secure set. CNTVOFF has very similar restrictions - it is only accessible when SCR.NS=1. No matter what the state of the NS bit, if you are in Monitor mode, you're in Secure state.
There's a good description of the banking and register accessibility on page B3-1459 of the ARM ARM (DDI 0406C.c). You can get a copy here: ARM Architecture Reference Manual ARMv7-A and ARMv7-R edition
There is a small spanner in the works, however, in that the effect of the write to SCR at line 11 only really takes effect after a context synchronization event - the ARM ARM defines what these are, but for now we'll just say that you either need some kind of exception return or entry (i.e. a mode change), or an explicit ISB instruction. Until that synchronization occurs, any instructions after the write may respect either value of the SCR.NS bit, depending on the state of the context. It isn't possible to know which instruction will see the effects of the SCR.NS=1 write unless such synchronization has happened. The discussion on synchronization of changes to system control registers directly follows the abovementioned description (B3-1461).
To be technically correct, the code should include have an ISB after the SCR write to ensure that the HVBAR and CNTVOFF writes will succeed (yes, in the original code, too), and the ISB before the "smc #0" is redundant (since it will perform the same action). Otherwise it could simply and randomly cause an unwanted exception, and since the MVBAR vector table isn't complete, it will spiral down the toilet -- the mcr will be an undefined instruction, and the undefined instruction exception vector is .word 0, which causes another undefined instruction exception, ad infinitum.
In terms of the requirement to use "smc #0" in Cortex-A7 initialization, this isn't necessary at all - it seems to be a concession to code size for this small bootstrap, and to allow future software such as U-Boot to execute that code path and return to it. The code itself seems to simply be a way to put the core (whichever it is, since there are four) in a good state and then loop forever until somehow given something else to run, or jump to 0x8000 if it's core #0.
One thing I am curious about is how you know that the CPS instruction is the cause or if you see the place it hangs (or the symptoms). Do you know that you are not in Monitor mode already? Do you have a debugger attached? I have to say I am a little confused as to exactly where your code is loaded, whether the RPi team's code is still loaded to 0x00 - 0xFF, and whether you're basically entering this from the U-Boot start.S code (when it calls "smc #0")? If your code runs after the RPi code?
Ta,
Matt Sealey
Hi, thank you for the detailed feedback.
I'll start with your question first: The "normal" configuration of the raspi is to run this code (which is linked at 0x0000) and then jump core 0 at 0x8000 where uboot/kernel/random code should have been linked. Using a config option, one can disable this behavior and make the board boot by executing code at 0x0, in monitor mode. In this configuration, no initial boot code from raspberry is executed. For my tests, I used this second booting option, linked their code at 0x0, and my code at 0x8000. Therefore, by modifying their code, I can see the changes once (if) I reach my own code. The issue with this approach is that I don't have any debugger, I use uart output to debug, thus the difficulty to debug this part of the boot code. I am really not sure where the board hangs during the boot, but I (wrongly) guessed it had to do with changing mode.
I think my main mistake was about the NS bit. I thought that you can only accessed the banked Secure CP15 register while in monitor mode, because monitor mode is always considered secure. If I understand correctly your explanation, I should add a ISB after line 11 so that I am sure to write to the correct version (non secure) of the CP15 registers. So if I want to exit in secure mode, I have to switch back to NS = 0 "after" this CP15 changes ? I'll try that today and come back to you with more feedback.
I think I finally understood what happens and I managed to do exactly what I wanted in the "boot" part of their code.
Just for the record, I added an ISB in the secure monitor, to be sure. And after changing the "non secure only" cp15 registers, I switch back NS to 0. Then, when I exit from the smc call, I am still in SVC secure mode.
I am now able to rewrite this boot sequence in another way, and setup a meaningful secure_monitor instead.
Thanks to your input, it was very helpful.
