Hi, arm experts,
We want to use ARCH32 mode in secure EL1, I see some descriptions in ARMv8 Arch Reference Manual about Secure EL1 ARCH32 mode as follows:
One is the VBAR(secure), it is mapped to VBAR_EL3, the other is SCTLR (secure), it is mapped to SCTLR_EL3.
That means secure EL1 and EL3 share VBAR and SCTLR?
Moreover, in SCTLR ARCH32 mode (G4.2.114 in ARMv8 Reference Manual), write M(bit 0) only means EL1 and EL0 stage 1 address translation enabled,
If EL1 and EL3 share SCTLR, how can I config it in ARCH32 mode?
That really confuse me, wait for your help, thank you!
Steven
One is the VBAR(secure), it is mapped to VBAR_EL3, the other is SCTLR (secure), it is mapped to SCTLR_EL3. That means secure EL1 and EL3 share VBAR and SCTLR?
No. What you are see is a difference in ARMv7 and ARMv8 handle secure/non-secure copies of registers.
In ARMv7-A, many of the system registers (e.g. SCTLR, VBAR, TTBR0) are banked by security state. Meaning that there two copies in the hardware. With the hardware automatically selecting the correct copy based on the current security state of the processor.
In ARMv8-A AArch64, this banking is no longer provided(*). You do have different copies of the registers for different ELs (e.g. TTBR0_EL1 and TTBR0_EL3), but not by security state. Meaning that your EL3 software software has to handle saving off one copy and loading in the other copy whenever you change security state.
What about ARMv8-A AArch32?
Whether you get the hardware banking (as in ARMv7) depends on the execution state of EL3.
If EL3 is using AArch32 --> You get the ARMv7-A style hardware banking
If EL3 is using AArch64 --> Your software has to handle the banking (regardless of the execution state of EL1)
(* There are a few registers that are still hardware banked, e.g. ICC_SRE_EL1, but not many)
Hi Martin,
I see the following description in armv8 manual(G6.2.114 SCTLR, System Control Register):
If EL3 is implemented and is using AArch32, there are separate Secure and Non-secure instances of this register:
When accessed as SCTLR(S):
EL0(NS) EL0(S) EL1(NS) EL2(NS) EL3(SCR.NS=1) EL3(SCR.NS=0)
- - - - - RW
So it seems that in a 32-bit mode system(EL3 runs in 32-bit mode), let's assume that system is running in armv7-compatible secure svc mode, if I want to configure SCTLR(S) register, actually I cannot read/write it directly, and it must have to be modified in monitor mode with SCR.NS = 0, is my understanding correct?
Thanks!
If EL3 is using AArch32, there will be two SCTLR registers --> SCTLR(S) and SCTLR(NS).
In Monitor mode, the SCR.NS bit controls which copy you will currently see.
So if you wanted to write to SCTLR(S), but currently SCR.NS=1, the you would need to the following:
MRC p15, 0, r0, c1, c1, 0 ; Write r0 to SCR, clearing NS bit (assume we've already set up r0) ISB ; ISB to ensure change to context is visible to following instructions MRC p15, 0, r1, c1, c0, 0 ; Write r1 to SCTLR(S)
NOTE: Monitor mode is the only mode in which you can see both copies of a banked register.
Should have added....
In Monitor mode, the SCR.NS bit is only controlling which copy of a banked register is accessed when you read/write it. It does _not_ change which one affects current execution. For example, it is SCTLR(S).M which controls whether the MMU is enabled for the Secure state (which Monitor mode is part of) regardless of the SCR.NS bit value.
Thanks for you quick reply, Martin!
I just noticed that there is no EL1(S) in "
So definitely all registers can be accessed with the same mode defined in armv7 specification in this case, just as you said. I understand now.
In addition, I have another question as below, could you help me about it?
To use AArch32 EL3, I know that AA64nAA32 pin can be configued as 0. My question is, if AA64nAA32 is configured as 1 when processor power up, i.e, system runs in AArch64 EL3 mode, and in this mode, if I use SPSR_EL3 to switch system to 32bit monitor mode, can we say that system will run in 32bit EL3 mode?
moonlight wrote: My question is, if AA64nAA32 is configured as 1 when processor power up, i.e, system runs in AArch64 EL3 mode, and in this mode, if I use SPSR_EL3 to switch system to 32bit monitor mode, can we say that system will run in 32bit EL3 mode?
Short answer, no - it'd be treated as an illegal exception return.
The execution state of the highest implement EL (*) can only change on a reset.
More generally, execution state (AArch32/AArch64) can only change on an EL change. An exception return from AArch64 EL3 to AArch32 Monitor mode isn't a change in EL (they're both EL3) - therefore there can't be a change in execution state anyway.
This also applies to the other ELs. So let's say you were in EL1 as AArch64, you can't do an exception return into one of the AArch32 EL1 modes. It would also be an illegal exception return.
To change the execution state of an EL you need, therefore, to be in a higher. So to change EL1 from using AArch32 to AArch64 (or vice verse) you'd need to be in EL2 or EL3.
(* EL3 and EL2 are optional.)
