Basic cortex A9 architecture question (memory area division)
Hello all,
I have a client who has the following requirement. He uses an Cortex A9 (dual core) based SoC chip .
The system has two Flash ROMs - Flash ROM 0 and Flash ROM 1. Each of these flash roms has a boot loader and user program.
On Reset, the CPU 0 jumps to the Flash ROM 0 and the boot loader stored in the Flash ROM 0 executes and do the minimal enough
H/W settings and then release the CPU 1 core from the reset status. CPU 0 core then transfer the "user program 0" to the SDRAM and CPU 1 core is responsible for transferring the "user program 1"  to the SDRAM in the memory location of different address ranges.
The expectation is, CPU 0 is taking control of transferring the User program 0 to the SDRAM and jumps over there and CPU 1 is taking control of transferring the User Program 1 to the SDRAM at different address location. Now, in the SDRAM memory there are two "User programs" running. I assume that I need to tweak some MMU settings to achieve this. But not able to find the pin-pointed information in the documents or I am not referring the right guides.
Please see the attached image which briefs the architecture and the requirement of my client. If possible, I want to restrict the
CPU 0 s ability to view the memory region of CPU 1 and vice versa.
CPU 0 controls User Progam 0 in the SDRAM memory and able to access only the defined memory region
CPU 1 controls User Progam 1 in the SDRAM memory and able to access only the defined memory region
Which document has the relevant information to understand the details I require? Any hints?
Regards
Senthil
