Hi, I am porting FreeRTOS to my M0+ device now.
I faced an issue CPU hang-up when DSB instruction executed.
Then Program Counter showed "FFFF FFFEh" and Exc value of xpsr is 0x03. So, I knew Hard_Fault error interrupt is happened.
But it has interrupt routine other address of FFFF FFFEh. So, I did not understand why CPU showed FFFF FFFEh address as PC value.
This is also weird, it was happening when I set -O0 of optimize level using GCC. It has never happen when using other optimize level...
I also check execute DSP instruction before starting RTOS of FreeRTOS. It can work properly....
Is there any hint to solve this issue?
Ponsuke606, not sure how this fits under "Infrastructure Solutions". This post has been moved to the "Cortex-A / A-Profile" category [1].
[1]: https://community.arm.com/developer/ip-products/processors/f/cortex-a-forum
