Hi expert
Since I debug AM3354(Cortex-A8 Core), I want to enable IRQ, so I write the assembler code:
IntrEnableIrq MRS R0, CPSR ; Pickup current CPSR BIC R0, R0, #0X80 ; Clear interrupt lockout bits in CPSR MSR CPSR_c, R0 ; Setup new CPSR value MOV pc, lr ; back
and I put a break point in
MSR CPSR_c,R0
and I run the program in full speed, then stop in MSR CPSR_c, then I run the program again,
but the program come to hard fault immediately.
I am sure the program run to error immediately, even not come to MOV pc, lr.
So I check the CPSR register's bits value,
Bit7(IRQ set bit is cleared) .
It is really confused me a long time, ARM Mode is 10111(ABT mode), and I can change IRQ(bit 7)from 1 to 0, then the program
come to error immediately , why this happen? I really need your help.
Best Regards
Jack
Hi JackShan,
The MSR instruction should not cause an abort, but maybe servicing a pending interrupt immediately after unmasking causes the abort exception?
You might want to look at the SCTLR and VBAR registers.
Also, you can determine the vector from the exception PC, which will tell you if this is a data abort or a prefetch abort exception.
Best regards,
Vincent.
