I can build bl31.bin for my i.MX8QM EVK (Arm Trusted Firmware open source reference) which can act as an Armv8-A bootloader.
I am NOT intending to include any u-boot binary in my test image. Is this possible ?
Can anyone suggest how to build a Cortex-A53 test image for i.MX8QM EVK with bl31.bin as the bootloader ? Any documentation or information ?
Following up with more info:
I'm able to boot the imx8qm using Arm Trusted FW and start an A53 core without u-boot. Just used the scfw_tcm.bin, mx8qm-ahab-container.img and bl31.bin to boot it. The debug console (for bl31) looks like this:
-- 0x1bffffffNOTICE: Memreg 2 0x34000000 -- 0x37ffffffNOTICE: Memreg 3 0x38000000 -- 0x3bffffffNOTICE: Memreg 4 0x60000000 -- 0x6fffffffNOTICE: Memreg 5 0x70000000 -- 0x7fffffffNOTICE: Memreg 6 0x80000000 -- 0xffffffffNOTICE: Memreg 7 0x400000000 -- 0x43fffffffNOTICE: Memreg 8 0x880000000 -- 0x97fffffffNOTICE: Non-secure Partitioning SucceededNOTICE: BL31: v2.3():NOTICE: BL31: Built : 15:21:46, Aug 24 2020INFO: GICv3 with legacy support detected.INFO: ARM GICv3 driver initialized in EL3INFO: BL31: Initializing runtime servicesINFO: BL31: cortex_a53: CPU workaround for 855873 was appliedINFO: BL31: Preparing for EL3 exit to normal worldINFO: Entry point address = 0x80020000INFO: SPSR = 0x3c9
Can someone explain the "Entry point address" ? Is it possible to launch secondary BL or app or other A53 cores ? Any examples ?
https://git.trustedfirmware.org/TF-A/trusted-firmware-a.git/tree/bl31/bl31_main.c
Entry point address is the first instruction address of next loaded image.
Yes, you can boot the secondary BL on other CA53 cores. Actually Arm Trusted Firmware is a good example for MP core booting.
- git.trustedfirmware.org/.../
