Time measurements ARM v8 platform running Linux
HI Everyone,
This is my first time here.
I need help about time measurements on a Cortex-A72 (Arm v8) 64-bit.
I have been trying to read the cycle counter (i have got root privileges on machine), but i can't.
my c code:
#define _GNU_SOURCE
#include <stdbool.h>
#include <stdio.h>
#include <stdlib.h>
#include <sched.h>
#include <unistd.h>
#include <inttypes.h>
#include <getopt.h>
#include <sched.h>
#include <assert.h>
#include <sys/stat.h>
#include <fcntl.h>
#define ARMV8_PMCR_E            (1 << 0) /* Enable all counters */
#define ARMV8_PMCR_P            (1 << 1) /* Reset all counters */
#define ARMV8_PMCR_C            (1 << 2) /* Cycle counter reset */
#define ARMV8_PMUSERENR_EN      (1 << 0) /* EL0 access enable */
#define ARMV8_PMUSERENR_CR      (1 << 2) /* Cycle counter read enable */
#define ARMV8_PMUSERENR_ER      (1 << 3) /* Event counter read enable */
#define ARMV8_PMCNTENSET_EL0_EN (1 << 31) /* Performance Monitors Count Enable Set register */
void arm_v8_flush(void* address)
  asm volatile ("DC CIVAC, %0" :: "r"(address));
  asm volatile ("DSB ISH");
  asm volatile ("ISB");
void arm_v8_access_memory(void* pointer)
  volatile uint32_t value;
  asm volatile ("LDR %0, [%1]\n\t"
      : "=r" (value)
      : "r" (pointer)
void arm_v8_memory_barrier(void)
  asm volatile ("DSB SY");
void arm_v8_prefetch(void* pointer)
  asm volatile ("PRFM PLDL3KEEP, [%x0]" :: "p" (pointer));
  asm volatile ("PRFM PLDL2KEEP, [%x0]" :: "p" (pointer));
  asm volatile ("PRFM PLDL1KEEP, [%x0]" :: "p" (pointer));
uint64_t arm_v8_get_timing(void) {
  uint64_t result = 0;
  asm volatile("MRS %0, PMCCNTR_EL0" : "=r" (result));
  return result;
void arm_v8_timing_init(void) {
  uint32_t value = 0;
  /* Enable Performance Counter */
  asm volatile("MRS %0, PMCR_EL0" : "=r" (value));
  value |= ARMV8_PMCR_E; /* Enable */
  value |= ARMV8_PMCR_C; /* Cycle counter reset */
  value |= ARMV8_PMCR_P; /* Reset all counters */
  asm volatile("MSR PMCR_EL0, %0" : : "r" (value));
  /* Enable cycle counter register */
  asm volatile("MRS %0, PMCNTENSET_EL0" : "=r" (value));
  value |= ARMV8_PMCNTENSET_EL0_EN;
  asm volatile("MSR PMCNTENSET_EL0, %0" : : "r" (value));
void arm_v8_timing_terminate(void){
  uint32_t value = 0;
  uint32_t mask = 0;
  /* Disable Performance Counter */
  mask = 0;
  mask |= ARMV8_PMCR_E; /* Enable */
  mask |= ARMV8_PMCR_C; /* Cycle counter reset */
  mask |= ARMV8_PMCR_P; /* Reset all counters */
  asm volatile("MSR PMCR_EL0, %0" : : "r" (value & ~mask));
  /* Disable cycle counter register */
  mask = 0;
  mask |= ARMV8_PMCNTENSET_EL0_EN;
  asm volatile("MSR PMCNTENSET_EL0, %0" : : "r" (value & ~mask));
 void arm_v8_reset_timing(void) {
  uint32_t value = 0;
int main(){
    int x =10;
    arm_v8_timing_init();
    arm_v8_memory_barrier();
    uint64_t time = arm_v8_get_timing();
    arm_v8_access_memory(&x);
    uint64_t time2 = arm_v8_get_timing();
    uint64_t delta =  time2 - time;
    arm_v8_timing_terminate();
return 0;
running this code with root privileges the compiler gives me the following error : Illegal Instruction.
trying to fix this problem I realized that MRS instruction gives me that problem.
Why ?
Thank You.
