Hi
I study coresight test with cortex A53 CPU.
I get FIQ interrupt when I running helloworld test in ini_libc function. But I don't known why.
I use gcc-linaro 4.9 toolchain : aarch64-none-elf-gcc with glibc 2.14
Set CPU config pin aa64naa32 to 1.
Do I miss something?
-----------------------------------------------------here is example boot code----------
mov x0, xzr mov x1, xzr mov x2, xzr mov x3, xzr mov x4, xzr mov x5, xzr mov x6, xzr mov x7, xzr mov x8, xzr mov x9, xzr mov x10, xzr mov x11, xzr mov x12, xzr mov x14, xzr mov x15, xzr mov x16, xzr mov x17, xzr mov x18, xzr mov x19, xzr mov x20, xzr mov x21, xzr mov x22, xzr mov x23, xzr mov x24, xzr mov x25, xzr mov x26, xzr mov x27, xzr mov x28, xzr mov x29, xzr mov x30, xzr
// Zero the stack pointers, link registers and status registers
mov sp, x0 msr sp_el0, x0 msr sp_el1, x0 msr sp_el2, x0 msr elr_el1, x0 msr elr_el2, x0 msr elr_el3, x0 msr spsr_el1, x0 msr spsr_el2, x0 msr spsr_el3, x0
// Initialise vector base address register for EL3 adr x1, vector_table msr vbar_el3, x1
// -----------------------------------------------------------------------------// Variable definitions// -----------------------------------------------------------------------------
// Values to set I and F bits in cpsr register//.equ I_BIT , 0x80//.equ F_BIT , 0x40// Values for different modes in cpsr register//.equ MODE_IRQ , 0x12//.equ MODE_ABT , 0x17//.equ MODE_UND , 0x1b//.equ MODE_SYS , 0x1f
// -----------------------------------------------------------------------------// Initialise stack pointers// -----------------------------------------------------------------------------
// Use CPU No to calculate stack pointer adr x1, stack_top mrs x2, mpidr_el1 and x2, x2, #0xFF // x2 == CPU number mov x3, #CPU_STACK_SIZE mul x3, x2, x3
mrs x2, mpidr_el1 and x2, x2, #0xFF00 asr x2, x2, #8 // x2 == Cluster number mov x4, #(CLUSTER_STACK_SIZE) mul x2, x4, x2 // 4stack_size x clusternum add x3, x3, x2 // add 4 X cluster num x stack size
sub x1, x1, x3 mov sp, x1
// Ensure all writes to system registers have taken place dsb sy isb sy
// Enable interrupts msr DAIFClr, #0xF// Configure FIQ to be taken at EL3 by setting SCR.FIQ.// This allows a FIQ to wake CPUs that wait in WFI in EL3// at the end of the boot code. mrs x0, scr_el3 orr x0, x0, #(1<<2)// FIQ bit orr x0, x0, #(1<<1)// IRQ bit msr scr_el3, x0
// -----------------------------------------------------------------------------// Start the test// -----------------------------------------------------------------------------cpu_start:// SelectCPU is run first so that only the selected CPU will run initialisation.// The cpu selection could instead be done here to fit the requirements of specific systems// For gcc we need to call init_libc to handle initialisation of c librarys etc before starting main// Once main has returned _exit will finish the simulation using the function specified in gcc_retarget.c bl SelectCPU bl init_libc bl main b _exit
simulation message
ncsim: *W,DSEM2009: This SystemVerilog design is simulated as per IEEE 1800-2009 SystemVerilog simulation semantics. Use -disable_sem2009 option for turning off SV 2009 simulation semantics.Loaded snapshot worklib.cortexa53_intkit_tb:vncsim> runcxdt.bin( 21825ns ) CPU0: Unexpected exception: curr_el_spx_fiq( 29005ns ) CPU0: ** TEST FAILED**CPU0 terminated the test at 29865ns (2986 cycles)Simulation complete via $finish(1) at time 29865 NS + 1
I found a problem !! I need enable cache before running init_libc it will call dc zva instruction.
