I am currently trying to understand (and possibly diagnose) a fault that we are seeing on a Cortex A53 CPU within a Xilinx Zync Ultrascale MPSoC FPGA. The problem occurs when firmware (bare metal) performs PCI express enumeration. The core SError faults when a configuration write access (memory write to SoC peripheral register) is attempted although configuration reads are okay. Though the problem is very likely to be a hardware problem (these are new prototype boards we have designed and built, of which 2 work fine and 2 give this error), I have found little documentation that describes how SError exceptions occur, beyond the flushing of cache data generating a fault asynchronous to program execution as mentioned in the documentation relating to sync/async exceptions.
developer.arm.com/.../synchronous-and-asynchronous-exceptions
So my question is, is there any more documentation/discussion available from an A53 ARM core perspective on what causes an SError exception?
Thanks in advance, Kevin.
Note: I did found a blog article on exception handing that had a link to an ARM forum post which sadly doesn't seem to exist.
community.arm.com/.../re-what-is-serror-detailed-explanation-is-required
Hi KPK,
The ESR gives details about what caused an SError.
The Cortex-A53 TRM gives more details about the ESR specific conditions on A53, like e.g. "SLVERR on external access".
Thank you for quick reply. I'll add the extra decoding to the exception handler. Forgot to say that I'm running in EL3, but I guess that does not make any difference.
Kevin
