Hi ARM folks, hoping someone can show me where I'm going wrong programming the MMU. The ESR_EL1 reports that it is a Permission fault, level 2. Here's what I'm trying to accomplish:
4GiB space, 4kiB granule flat identity mapped, divided like this:
0->1GiB: normal RAM (only 1G of RAM on this machine)
1->4GiB: device memory
And the normal RAM segment is to be divided into 512 x 2MB pages in a L2 table. My configuration is below. Any tips on what I'm doing wrong or how to debug is greatly appreciated!
PE State
EL1H
Registers
ESR_EL1 = 0x8600000E -> MMU fault, Permission fault, level 2
SCTLR_EL1 = 0xC00801 -> just RESVD1 bits and MMU enable bit set
TTBR0_EL1 = 0x8E000 -> base address 0 for translation tables
TTBR1_EL1 = 0x8E000 -> base address 1 for translation tables
TCR_EL1 = 0x35203520 -> 4GiB space, 4kiB granule inner shareable normal inner/outer cacheable for both TTBR0 and TTBR1
MAIR_EL1 = 0xffffffffff440400 -> ATTR0=device ATTR1=device ATTR2=normal non-cacheable ATTR3-ATTR7=normal cacheable
1st Level Table @ 0x8E000 (dumped with GDB)
0x8e000: 0x8f003 -> table pointer to next level table, table is 512 x 2MiB entries
0x8e008: 0x40000741 -> 1GiB device mem @ 0x40000000
0x8e010: 0x80000741 -> 1GiB device mem @ 0x80000000
0x8e018: 0xc0000741 -> 1GiB device mem @ 0xC0000000
1st Level Table @ 0x8F000 (dumped with GDB, truncated)
0x8f000: 0x74d
0x8f008: 0x20074d
0x8f010: 0x40074d
0x8f018: 0x60074d
0x8f020: 0x80074d
0x8f028: 0xa0074d
0x8f030: 0xc0074d
0x8f038: 0xe0074d
0x8f040: 0x100074d
... truncated ...
Adapted from: http://infocenter.arm.com/help/topic/com.arm.doc.dai0527a/DAI0527A_baremetal_boot_code_for_ARMv8_A_processors.pdf
Using openocd's virt2phys function I can see that my mappings are working as expected for normal and device mem, and thay unmapped areas fail at stage 1 as expected:
> virt2phys 0x82c30
Outer shareable, Not Secure
Normal Memory
Physical address 0x00082c30
> virt2phys 0x41000000
Device Memory
Physical address 0x41000000
> virt2phys 0x81000000
Physical address 0x81000000
> virt2phys 0xC0000000
Physical address 0xc0000000
> virt2phys 0xC0000001
Physical address 0xc0000001
> virt2phys 0x1F0000000
Address translation failed at stage 1, FST=4, PTW=0
This topic might be of some help.
