Dear Experts
I am working on a target that contains quad A53 cores operating at 1GHz. The operating system idle loop contains WFI inline assembly instruction. I know that the Core Clock halts during the WFI instruction which can be seen on the PM_CCNTR counts.
I was thinking if I can utilize this fact to get some figures around the system cpu_load. The idea is if I am sampling the PM_CCNTR on a regular bases with time stamp. I can use these time stamps to calculate the diff time between to consecutive samples. do the PM_CCNTR diff value can be indicative to the cpuload?
example: if I am sampling every 10ms seconds I should expect 10,000,000 counts if the core utilization is 100%. If I got 7,000,000 this means that the core spent 30% of the time in the idle loop. hence, the cpu load should be 70%.
Note: there is no where else on the code where WFI is been used.
My question: Is this methodology make sense? Is there any thing that could alter the core clock other than the WFI instruction? What else should I take into account?
Which OS? (Or is it top-secret?)
Linux e.g. might throttle the CPU if idle.
What do you mean by throttling the cpu exactly? If you mean decrease the core clock input, is that doable on the Cortex-A53?
Anyway, the operating system I use does not do that at all.
