Hi all i trying do transition from EL3 to EL2 exception ,but after ERET of EL3 mode it change the mode to EL2 , but as soon as when it will execute first instruction of EL2 , then It goes to Exception ...
This is happen for every secure to non secure transition in Armv8-A .
Please Guide if you know why this happen?
Thank you in advance.
Regards
Sanjay Kumar
Hi. For background reading I suggest you take a look at the "Boot: Bare Metal" guide linked to from this page:
developer.arm.com/.../learn-the-architecture
Specifically chapter 5.5, it talks about moving between Exception levels.
On to your specific question, there's a couple of things that could be going wrong. The value in ESR_EL3 when you re-enter EL3 should tell you what. Common problems:
.global test_el3_to_el2_asm .p2align 2 .type test_el3_to_el2_asm,%function test_el3_to_el2_asm: #store return address into C world - this will be retrieved from SMC handler adr x0,return_addr str x30,[x0] #set sp_el1 to sp_el3 in order for the code in C test function to work ldr x0, =__stack_end__ mov x1, #1000 sub x0, x0, x1 bic x0, x0, #0xf msr sp_el1, x0 mov x1, #1000 sub x0, x0, x1 bic x0, x0, #0xf msr sp_el0, x0 mov x1, #1000 sub x0, x0, x1 bic x0, x0, #7 msr sp_el2, x0 //Initialize SCTLR_EL2 and HCR_EL2 to save values before entering EL2. MSR SCTLR_EL2, XZR MSR HCR_EL2, XZR MRS X0, HCR_EL2 ORR X0, X0, #(1<<19) ORR X0, X0, #(1<<31) MSR HCR_EL2, X0 //clear CPTR_EL3 and CPTR_EL2 to prevent trapping of accesses to CPACR at EL1 bl clear_cptr_el3_el2_asm // Determine the EL2 Execution state. MRS X0, SCR_EL3 ORR X0, X0, #(1<<10) // RW EL2 Execution state is AArch64. ORR X0, X0, #(1<<0) //NS=1 El1 Non Secure state BIC X0, X0, #(1<<3) MSR SCR_EL3, x0 isb MOV X0, #0b01001 // DAIF=0000 MSR SPSR_EL3, X0 isb // Determine EL2 entry. ADR X0, el2_entry // el2_entry points to the first instruction of MSR ELR_EL3, X0 // EL2 code. ERET el2_entry: nop add x0, x0, #1 smc 0x0
Hi @Martin Weidmann , Thanks for reply... above is my code for Transition from EL3 to EL2 and again return to EL3 but the problem is while Executing first instruction in EL2 mode then it goes to again EL3 mode and goes to unexpected handler.
Please check above code suggest me .
Thank You.
Regards,
Can you share the ELR_EL3, SPSR_EL3 and ESR_EL3 values when execution returns to EL3? Also, what's the address of el2_entry (for comparison to the reported ELR value)?
NO after execution first instruction of EL2 mode, it is remains in EL2 mode only but it goes into unexpected handler..so i cant read EL3 regions registers.
