I'm researching the the <Arm Architecture Reference Mannual ARMv7-A ARMv7-R edition> these days. when i read about the exception handling part of this mannual,it come accross a confussion to me,the problem is how to dicide the instruction address to which the exception should return back.
here is the method mentioned in the document:
Suppose that the processor is excuting an instrction at 0x_0000_1000 and an IRQ was taken to IRQ mode
according to the document, we can get the return information of this exception as follows:
1)Preferred return address : Address of next instruction to execute(in this case is 0x_0000_1002 for thumb instruction set state and 0x_0000_1004 for arm instruction set state).
2)LR : preferred return address plus an offset that depends on the instruction set state when the exception was taken(in this case LR = 0x_0000_1002 + 4 for thumb instruction set and 0x_0000_1004 + 4 for arm instruction state),so LR = 0x_0000_1006 for thumb instruction set state and LR = 0x_0000_1008 for arm instruction set state.
3)PC : in this case PC = 0x_0000_1000 + 4 for thumb instruction set state and PC = 0x_0000_1000 + 8 for thumb instruction set state.
4)the document gives a Pseudocode to calculate the LR by using the parameter PC
LR = PC - 0, in thumb instruction set state. in this case is LR = 0x_0000_1004 - 0 = 0x_0000_1004
LR = PC - 4, in arm instruction set state. In this cse LR = 0x_0000_1008 - 4 = 0x_0000_1004
Here we can see that we can get a dirrent LR by the means of 2) and 4),what's going wrong with my calculation?which method is right?and how to calculate the final return address ? by the way,my english is so poor,shamed,hope u can understand what i'm trying to express...
(4) Shows what the core does. Not what your SW should do.
thanks, but how about (4), is there anything wrong with this method or anyting I misunderstand with this method?
Just take (2): Substract 4 (or 8 in case of virtual/data abort) from the LR to get the return address.
