I have code which runs on Cortex-A72 (AArch64) and it disassembles to the following: 0: d53800a9 mrs x9, mpidr_el1 4: 92400529 and x9, x9, #0x3 8: b4000069 cbz x9, 0x14 c: d503205f wfe 10: 17ffffff b 0xc 14: 10ffff69 adr x9, 0x0 18: 9100013f mov sp, x9 // write to uninitialized memory beyond executable image (BSS section) 1c: 90000008 adrp x8, 0x0 20: 91016108 add x8, x8, #0x58 24: c85ffd09 ldaxr x9, [x8] 28: b2720129 orr x9, x9, #0x4000 2c: c80afd09 stlxr w10, x9, [x8] 30: 35ffffaa cbnz w10, 0x24 // turn on ACT LED -- this code never executes 34: d2bfc404 mov x4, #0xfe200000 38: b9401080 ldr w0, [x4, #16] 3c: 12177000 and w0, w0, #0xfffffe3f 40: 321a0000 orr w0, w0, #0x40 44: b9001080 str w0, [x4, #16] 48: 52808000 mov w0, #0x400 4c: f9001080 str x0, [x4, #32] 50: 14000000 b 0x50The problem is it enters infinite loop with stlxr/ldaxr and I have no idea how to debug or where to look at to resolve the issue.I've read about exclusive access monitor in the ARNv8-A Reference Manual: aarch64/functions/exclusive/AArch64.ExclusiveMonitorsPass // AArch64.ExclusiveMonitorsPass() // =============================== // Return TRUE if the Exclusives monitors for the current PE include all of the addresses // associated with the virtual address region of size bytes starting at address. // The immediately following memory write must be to the same addresses. boolean AArch64.ExclusiveMonitorsPass(bits(64) address, integer size) // It is IMPLEMENTATION DEFINED whether the detection of memory aborts happens // before or after the check on the local Exclusives monitor. As a result a failure // of the local monitor can occur on some implementations even if the memory // access would give an memory abort. acctype = AccType_ATOMIC; iswrite = TRUE; aligned = (address == Align(address, size)); if !aligned then secondstage = FALSE; AArch64.Abort(address, AArch64.AlignmentFault(acctype, iswrite, secondstage)); passed = AArch64.IsExclusiveVA(address, ProcessorID(), size); if !passed then return FALSE; memaddrdesc = AArch64.TranslateAddress(address, acctype, iswrite, aligned, size); // Check for aborts or debug exceptions if IsFault(memaddrdesc) then AArch64.Abort(address, memaddrdesc.fault); passed = IsExclusiveLocal(memaddrdesc.paddress, ProcessorID(), size); ClearExclusiveLocal(ProcessorID()); if passed then if memaddrdesc.memattrs.shareable then passed = IsExclusiveGlobal(memaddrdesc.paddress, ProcessorID(), size); return passed; aarch64/functions/exclusive/AArch64.IsExclusiveVA // An optional IMPLEMENTATION DEFINED test for an exclusive access to a virtual // address region of size bytes starting at address. // // It is permitted (but not required) for this function to return FALSE and // cause a store exclusive to fail if the virtual address region is not // totally included within the region recorded by MarkExclusiveVA(). // // It is always safe to return TRUE which will check the physical address only. boolean AArch64.IsExclusiveVA(bits(64) address, integer processorid, integer size);Could it be something related? I don't enable address translation and I don't initialize exclusive access monitor. Do I need to?Any advice or help is highly appreciated. Thanks in advance!
AFAIK you need to have MMU on and the memory must be mapped a normal memory to have LDAXR/STLXR working.
