Given a multiprocessor system, how are the PC values of secondary cores set from the primary core? I've read lots of threads stating it can be done but without any details. I could not find anything in the ARMv8 reference manual.
One might contrive a mailbox system where the secondary cores wfe and check the value of a mailbox address when woken up. But is there a supported method to directly write the secondary core PC before waking it up? What are the various methods for "waking up" a core?
I've been prototyping with QEMU. I had no idea something like this might be SoC-specific. I've seen entrypoint address registers in some NXP SoCs but I was not sure what was standardized for this kind of thing.
The PSCI reference made above is an interesting one. After reading into the documentation I find it confusing how actions such as CPU_ON/OFF and SUSPEND can be had through an SMC if cores are unable to influence the PC of other cores. Unless they are not considering the PC and just using some other means to shut the core down? Can that be done?
PSCI is AFAIK part of the trusted firmware which runs below all other software. So when you tell it to "start" a CPU it will take the actions described before. Only, the started CPU will boot into the trusted firmware and then jump into the user code.
The trusted firmware is always present on each running core. A CPU_OFF on one core will likely send a message (via IPI) to the other one to handle this.
But the basic principal is the same: A core starts from a fixed address. Often 0, sometimes (high vectors) 0xfff0.0000. On iMX8, you have to set a SoC register with the start address. But it is likely that the started core first executes ROM code in the SoC and then the ROM code jumps to the address in the SoC register.
But I do not know how QEMU handles this. Maybe all cores are started but loop and check a specific memory address for a start address.
It depends on how you are using QEMU. I've been using it in such a way that I'm writing the "firmware" for the emulator. My code is mapped into the Flash region and each core starts executing the first instruction (address zero) on reset. So it's entirely up to me I suppose for how this is done.
Thanks for the info.
It took me a bit of poking around to finally uncover that IPIs on ARM are referred to as LPIs, for anyone here after me that might be searching for the same thing. Implemented in the GIC.
Hi 42Bastian Schick,
In my case I see qemu emulates PSCI called with HVC.
You can ask qemu to dump the dtb with:
qemu-system-aarch64 -machine virt,dumpdtb=dump.dtb -smp 4 ...
Then you can "disassemble" the dtb with:
dtc -o dump.dts -I dtb -O dts --sort dump.dtb
You will see the cpu nodes in there referring to PSCI:
cpus { #address-cells = <0x01>; #size-cells = <0x00>; cpu@0 { compatible = "arm,cortex-a72"; device_type = "cpu"; enable-method = "psci"; reg = <0x00>; }; cpu@1 { compatible = "arm,cortex-a72"; device_type = "cpu"; enable-method = "psci"; reg = <0x01>; }; cpu@2 { compatible = "arm,cortex-a72"; device_type = "cpu"; enable-method = "psci"; reg = <0x02>; }; cpu@3 { compatible = "arm,cortex-a72"; device_type = "cpu"; enable-method = "psci"; reg = <0x03>; }; }; ... psci { compatible = "arm,psci-0.2\0arm,psci"; cpu_off = <0x84000002>; cpu_on = <0xc4000003>; cpu_suspend = <0xc4000001>; method = "hvc"; migrate = <0xc4000005>; };
Best regards,
Vincent.
