Guidelines on reducing Cache Miss rate
Hi Experts,
Is there any document on general software guidelines in reducing the cache miss rate in the system for ARMV7 architectures ?
If it is more specific to A/R/M then its great..
  • It would be good to have a good book or website about that. I can give a couple of tips
    Get a package which somebody else has optimised
    Else if you're a lot more desperate
    For matrices try and work with tiles, square patches, at a time that fit easily in the cache. There's a lot of work done on strategies in this area so finding an algorithm is best.
    When going down a list prefetch the link to next node before working on the current node. If you're going to use a linked list a number of times it may be worthwhile arranging it into a table or a contiguous list in order at the start.
    Do a few threads of similar work, say four of them, in parallel in software like emulating a multi-core processor. Prefetch anything that might cause a cache miss then do the next bit of work on the next thread and cycle round the threads that way.
    Study your processor to see what problems might be caused by clashing cache addresses and try and ensure you avoid clashes. This used to be an awful problem in the past but ARM processors have usually been some of the better ones this way.
  • A quick google on "reduce cache miss rate" turns up this page: Reducing Cache Miss Rate which is quite useful.
    Most recent ARM cores support prefetch instructions like PLD, PLI etc. These can improve the performance of loops, especially through data which exhibits low locallity.
    Very often, though, the most important thing you can do is look at your algorithm. And then look at your implementation of that algorithm. A zero-copy algorithm can make better use of available cache space, for instance. And a simplistic implementation of a matrix multiplication operation will often show very poor performance, especially for matrices which are large compared to the cache size, because of a high level of contention. Re-implementing it using strips or blocks/tiles can improve performance by increasing the amount of reuse of cached data.
    Think also about data structures. Sparse arrays and linked lists often cache extremely poorly and actually the effect of caches in these cases if sometimes to actually increase memory traffic rather than reduce it.
    Another good technique is to align data structures with cache line boundaries. If an individual data element fits within a cache line then the whole element can be loaded with only one cache miss.
    There is a lot of other useful material out there.
    Hope this helps.
    Chris
