ARMv8 memory ordering
In the ARM Architecture Reference Manual issue D.a (ARM DDI 0487D.a) section K11.3.1 "Acquiring a lock" has the following example code:
AArch32
Px
        PLDW[R1]                     ; preload into cache in unique state
Loop
        LDAEX R5, [R1]               ; read lock with acquire
        CMP R5, #0                   ; check if 0
        STREXEQ R5, R0, [R1]         ; attempt to store new value
        CMPEQ R5, #0                 ; test if store suceeded
        BNE Loop                     ; retry if not
        ; loads and stores in the critical region can now be performed
My question is I can not find documentation  in Chapter E2 "The AArch32 Application Level Memory Model" that would prevent a speculative store after the BNE from being accelerated before the STREXEQ causing the store to be observed by another observer before the lock is acquired.
Version A.j of the manual contained the following statement: "Speculative writes by an observer cannot be observed by another observer." Which would preclude this from happening but I can find no equivalent statement in the latest manual.
