Why the address width of MMU-500 is different with Cortex-A53/57?
I find the description below from MMU-500 TRM.
Address width
The incoming address width is fixed at 49 bits, where A[48] specifies VA sub-ranges. You must tie all unused bits to zero. The output address width is 48 bits and the width of the AC address
bus is 48 bits.
But I know that the AXI address width of Cortex-A53/57 is 44 bits.
So If Cortex-A53/57 and MMU500 are connected with the same CCI-400 interconnect, will CCI-400 ensure the matching of  address width, or will MMU500 only connect 44 bits output address with CCI-400?
And I find that the address width of Cortex-A7/15 and MMU-400 is 40 bits, I am confused about MMU-500.
Would you please kindly explain this? Thanks.
