i have the Zedboard which contains arm Cortex-A9 cortex with the amba bus..
i have searched a lot but I probaly miss the point.
i want to use data and to transfer data from the processing system to the programable logic section via the amba bus
is there any library for c that have function to implement the amba bus ?
for example
sendDatatobus(data,addr)
or something like that?
how do I do it?
thank you!
idan.
The hardware cores that you connect to the AMBA bus have a corresponding device driver. This driver includes all needed functionality and clear documentation. You can use Vivado or XPS to generate your SoC and then SDK to view device driver documentation and implement application software. All tools are available through Xilinx. I am not aware if ARM DS5 can be used instead of Xilinx SDK, but if I find I will keep you informed.
