I find Arm has 16 bit immediate value load to register instruction, but it has no instruction to load 32 bit value to register. I am new to asm level programming. How many ways to load a register to a desired value for an Arm CPU?
thanks,
As ARM instructions are 32-bits the short answer is "you can't"
However, one of the best options is to use the format:
LDR Rn, =<constant>
The assembler will then work out whether it can use a MOV, MVN or LDR from a literal pool,
for example:
LDR R0, =0xFFFF43FF
should resolve to
MVN R0, #0xBC00
If the value can't be resolved this way, then it will use a relative load from a literal pool, e.g.
LDR Rn, [pc, #<offset>]
DCD <constant>
This blog may be useful:
How to Load Constants in Assembly for ARM Architecture
In particular it shows how to use MOVW and MOVT to load two 16-bit constants from the instruction steam, which is often a better solution that a literal load (which pollutes the D-Cache).
