For those of ARM's customers, who design microcontrollers, I would like to recommend a Big Endian implementation (or at least an option to select Big Endian).
This is due to that I have designs that need to work with Big Endian data.
Big Endian is the network native endianness, thus it would be a good optimization for IoT.
In addition, Big Endian is less confusing. Using Big Endian results in fewer programming bugs (bugs that are introduced due to confusion, not necessarily the actual memory organization).
In my case, I would need Big Endian + Network + LCD + 2*I2S + EMC + SD/MMC + high speed + a free (fast 65MHz+) GPIO[31:0] + a fair speed GPIO[15:0].
-So that's a chip with a lot of pins.
(Note: This was originally posted under Cortex-M7, as it's my wish that there will be Cortex-M7 microcontrollers with the mentioned features)
Big endian is quite well supported. It isn't quite as well supported as little endian because ARM was originally entirely little endian and there are some niggles like the format of the instructions and control space registers, but it is supported to compete in networking like you say. You can get big endian versions of the compilers and some of the operating systems. If getting a development board you'll need to check that it is always big-endian or has a switch to enable it.
Unfortunately, I haven't come across any big endian Cortex-M yet. (Or I may have come across it but didn't spot that it could support big endian).
For GCC, you can just supply a switch on the command-line and you're building big-endian binaries.
As you mention; I believe that the instruction set is always little endian (that doesn't matter much, unless you're making self-modifying code or code that builds other code, though)
On a quick look I would have to agree you are right whatever about the possibility mentioned in the reference manual. Cortex-M chips seem to be universally little-endian with no possibility of using big-endian either via a reset pin or some configuration register. And the development environments don't have it as a standard option. I guess any network chips must use A series chips instead so they can run full Linux with a MMU, if you're using a Cortex-M I guess you'd just have to use the hton etc macros.
It looks to me like the little-endian only is a deliberate choice probably to cut down variety and so lower support costs. The code would probably be of a manageable size rather than the huge wadges of legacy code one gets with bigger systems. So any change there would probably need a very good case.
Yes, many Cortex-A (perhaps all) offers big endian support.
But I am positive, that the Cortex-M could benefit strongly from having big endian implementations.
Most people don't know what big endian is, because they've worked with little endian all their lives; they know bytes are arranged MSB first, etc, but they do not know the benefits of programming in a big endian environment.
I've been working with both big and little endian for many years, and I absolutely prefer big endian (everything is logical, also bit-shifting).
Some of the benefits are that the sign-bit is the most significant bit and is stored in the Most Significant Byte, thus it'll always be at byte[0].
Reading fixed point values from memory also results in fewer operations.
Standard image (pixel) conversions can be done in less operations.
Network code can use the values directly, reducing code size and increasing performance (using less CPU time for networking)
Various peripherals expect bytes stored/sent as MSB first; I2S for instance, would benefit from this as well.
The rev instruction is a good instruction, however I wish that ARM had made load-with-byte-reverse and byte-reverse-store instructions.
That would have solved most of the problems, which has to do with performance.
If a load takes a uses a single cycle and a store uses a single cycle, then converting a 32-bit value in memory would use 3 clock cycles.
Compared to the above, a load-with-byte-reverse and a store (or a load + store-with-byte-reverse) would use only 2/3 of the time.
But in general, there are still problems when disassembling ARM code using objdump or OpenOCD.
If you dump a 16-bit value, you do not see the actual values, but they're byte-swapped "for clarity". This is highly confusing.
Same about 32-bit values.
And the disassembly is so confusing that I have not yet been able to find the pattern.
-So even these approaches to "fix" the little endian problem (I call it little-endian bug, heh, no offense meant to anyone who likes little endian), have not been successful.
I would expect that Freescale would be among the first companies to make a Cortex-M with big endian support. Especially because their previous architectures are big endian and they already know the benefits, but also because they seem to provide a broad palette of choices in their Cortex-M range.
I know that other companies are very open to suggestions (they're good listeners), so I believe there's a chance there will be more than one big endian provider, when it comes to Cortex-M.
