hi,
after some time i think its time to learn arm programming, i used to program for avr, (im mainly a pc programmer ! young one )
i got an Raspberry pi model b+. but i don't want to use it for making fun stuff or hobby, i want to do real programming(not that python and pi are not real programming i can't explain what i mean) , so i can work somewhere(i don't want to but example of what i mean, im not looking to make stuff, im looking to learn!!!) or make products! (like nest self learning thermostat or the Parrot ar.drone)
raspberry pi has an os and its a big boards and has unneeded stuff so i don't want to use it on my final product (release it with a pi inside of it!)
like in avr i wrote my c program for my chip on breadboard, or an arduino, after that i just installed the final version into a chip ans inserted it into a final cricut , but not the whole arduino! (like lets say i made an automatic cat feeder and released it for public!!! )
i want to do the same, so my question is:
how can i start it? Do i need to know Assembly? i only know a little bit of PC assembly, it sounds cool
i heard different MPU/MCU's require learning the whole thing again, i may use different stuff on different projects, that means i have to learn it again for each project?!
lets say my goal is to make AR.Drone from scratch, by buying motors the chips and ect, but i want to prototype it with pi first, and the OS and other stuff just require battery and waste resources , how can i do it?!
so what should i do/learn to make an AR.Drone?! (i know its not like i wake up and decide to build a time travel machine but i will learn what's necessary because i have time and im looking to learn !)
sorry if this question sounds stupid but i have been really confused these days so i thought its good to make a thread!
EDIT:
let me summirize it a little !
Summary:
im moving from AVR programming to ARM,
what steps i should take? what should i learn?
i want to use ARM for making products and devices , i already bought an pi to prototype before i can make it a product , in its own board with other stuff in the board
a good example of what i want is ar.drone !
I'm not understand when you say your program only works with pi ? What is it so specific that create this malfunction on other board ?
the python program
import RPi.GPIO as GPIO
GPIO.setup(GPIO.BCM)
GPIO.setmode(GPIO.OUTPUT);
ect
wont work on my custom board with an different ARM right? not the Pi's Cortex but different model !
also my main problem with Pi is the size and price ! creating my own boards with desired Ram and MPU and storage for program is cheaper and smaller !
if the ar.drone didn't exist now and i was hired by parrot (ofc im not ) it wouldn't work good with a pi !
a company can't just simply use a board like pi in they're product even if they could!
i know its a lot easier with Pi, but i can work harder
in both nest thermostat and Ar.drone neither use pi and both have their own custom designed boards!
i want to learn programming arm from now for future ! because i find it useful, and maybe i will study electronics
sorry if im annoying you
I want to make my own embedded system board !
I think what you're saying is that you want a microcontroller, which has both flash-memory and SRAM built-in.
And you do not want a horribly lot of other semiconductors / components.
If that is the case, it might be the easist for you to use a Cortex-M3 or Cortex-M4 (like daith says).
If you require a lot of heavy calculations or very high speed, you may want to look for a Cortex-M4.
You'll easily be able to find Cortex-M3 running at 50 MHz, 72 MHz, 100 MHz or 120MHz.
Many Cortex-M4 runs at 50 MHz, 100 MHz, 168 MHz, 180 MHz and 204 MHz.
I've seen Cortex-M0+ running up to 48 MHz.
Cortex-M0 is usually good for energy-saving, however, a Cortex-M3 or Cortex-M4 does not use extremely much energy.
Compared from what you know, the AVR, a Cortex-M device is definitely both faster and gives better possibilities.
It also enables you to change more than 8 GPIO-pins at a time.
The most 'difficult' thing to learn about the ARM-based microcontrollers, is that you need to turn on power to the peripherals you want to use.
On some devices, you also need to place a (usually pull-up) resistor on a boot-pin (and avoid that this pin is pulled low during reset).
You can download the tools you need for free.
Normally, those tools will allow you to program in C, C++ or Assembler.
Some of the tools might give you more options.
I'm usually buying adapter-PCBs (such as LQFP144 adapter PCBs, and a Cortex-M3 or Cortex-M4 chip.
I then solder the chip onto the adapter PCB and add a few pin-headers.
I make sure that I solder the pin headers so the adapter PCB can be inserted into my solderless breadboard.
From there and forward, it's easy building your design, as long as you remember 100nF capacitors from each VCC line to GND.
If you decide to take the route I use, you will need a JTAG-adapter or if you have a Windows-based computer, you can often just use the serial port for flash-programming the Cortex-M.
You will need to verify this in the specific microcontroller's datasheet, though. Nowadays, many devices also allow you to flash-program them via USB.
The question now is which microcontroller that fits your needs.
Depending on where you live, you might be able to find some at Farnell for instance.
Ff you click the link, you will see I've sorted Cortex-M microcontrollers by price.
Click on the PDF icon under the picture of the device, in order to get the datasheet.
Note: There's no guarantee that the picture of the device is correct.
In the column named "Architecture", you can see if it's a Cortex-M0, Cortex-M3 or Cortex-M4.
You will need to scroll down / go to next page, in order to find Cortex-M3 and Cortex-M4 devices.
If you need to use the microcontroller for motor-control, then you may want to take a look at LPC1549.
NXP has an evaluation board for this device, which you might find interesting.
The special thing about the LPC15xx is that it has a lot of PWM channels, so it's particularly good for controlling motors.
Though I am very fond of NXP, there are many other devices that you might find interesting.
Nordic Semiconductor and Freescale both makes ARM Cortex-M microcontrollers that have wireless features.
thanks this answered 99% of my questions
but there's still something, what about the rasp i bought, it was a waste of money ?
also can you give me a link of a book or a website i can start learning how to do it?! and my country is a joke , this is the only arm based board i can find (i guess !) maybe i could also find the beaglebone !
and Pi has USB and camera ports i dont need those ! but if i wanted to get a flash ram and ect for my board can i program the A series the same way?! i don't have better way to say it but using a total raspberry pi in a drone or product is kinda, well lame ,like i would not use an arduino uno if i was a company, that was also waste of money for my costumers !
but i can't learn how to program A series with my Pi?! i already spent a lot for it ! i begged my father for it
also maybe if i needed like streaming video or other stuff the A series sound better !
it doesn't matter if its build-in i could include the other parts in my Board
btw the Ar.drone still uses A series and is small i mostly want to learn the programming , not how to make the board ! i might study Electronics and ARM sounds extremely useful , so i thought its good to start learning how to from now! (im in high school now! but want to start learning from now)
edit: i see that some of those have only like 8 pins 0_0 2 of them are surely VCC and GND ! theres almost no other pins left for controlling !!! i remember i even sometimes had trouble with small amout of pins in my ATmega 328 xD (lcd and other stuff )
https://d3nevzfk7ii3be.cloudfront.net/igi/cmH6AkEgrAe32ckU.medium
ar.drone uses its own parrot ARM9 but i dont care what company makes the ARMx Processor, i want to learn to programm that, (as you told me about M series, but i still would like to know how to do that as you also see its in different shape and size )
The Raspberry Pi can be used for a lot of things; I do not think it's a waste of money in any way.
-I have a CubieBoard2, which I use for many things, for instance Web-server and git server.
I also use it for compiling and testing Cortex-M subroutines (because they run very fast on that platform).
(I use the compiler on the CubieBoard2 directly; in addition to my desktop computer)
I believe you could use your Raspberry Pi as a git-server. Git is very useful and you almost can't do without it, once you've learned how to use it.
Cortex-A is a completely different story. If you want to build with Cortex-A, you should probably try the Allwinner A10 or A13. Olimex sells LQFP versions of A13, which you would be able to solder by hand, if you are experienced. The BGA chips (A10, A20 and A31 for instance) can't be soldered by hand - you would need to ask a PCB-assembly service to do that for you. Note: The Allwinner microcontrollers are Cortex-A7.
As you saw on the list of Cortex-M devices, many of them have few pins only. This is usually those devices that cost very little.
You can find Cortex-M devices with up to 208 pins (LQFP versions) and 256 balls (BGA versions).
On Farnell's site, you can filter out packages with only few pins. Select the number of pins you want and click the Apply button.
You can also uncheck Cortex-M0 and Cortex-M0+ if you want. Those filters makes it much easier to quickly find what you're looking for.
Cortex-M is not so strong at the video side. You might find the Cortex-A7 a good choice there, especially if you need to compress the video before transmitting it.
But it might not be as easy to build a circuit board with the Cortex-A7 as it is building with Cortex-M.
Which country do you live in ? -If you're lucky, one of the big distributors have a department where you live.
thanks A lot
now i think i can use the 8pin, with AVR (Serial communication) the ARM does the thinking and tells arm what to do
i live in Iran(its a wonderland , its a joke) , i even had hard time finding my Pi, the Pi has the 700 MHz ARM1176JZF-S ! can't i use the ARM inside it to learn?
why would i need Git server ?! doesn't the git side give me a free space already 0_0?!
i found few here
http://kavirelectronic.ir/eshop/14-microcontroller
the website is persian but the model numbers are not few of them has ARM on them
they're like 7$~ but still cheap Atmel ones were like less than 1$ xD but not good as Arms
also how do i programm those? (do i need a programmer or somethin?! like i used to with avr!)
also now i think i can use my Pi to Steam from my pc to tv
and also if that helps i have Ubuntu 14.10 LTS 64bit i only use Windows for games
If you keep your repositories local, you do not need a git server.
However, I have a git server, because I work on a project where other people are involved, so we can push and pull from the server.
I know it's not easy to get what you want, when you live in Iran, but you seem to have found a good shop there!
The LPC1768 is one of my favorites; that's the first Cortex-M I had. (I still have it).
I can recommend this one, but I will also recommend you to look at the datasheets for the other microcontrollers. I've seen there's a LPC1769 as well; this is 120 MHz, where the LPC1768 is 100 MHz.
I know the LPC1768 and LPC1769 can be programmed via both JTAG and SWD. They can also be programmed via UART0, so if you have a USB-to-UART adapter, you can use a small free utility to upload the program to the LPC1768/69. I know there's something called LPC_DFU, which you should be able to use, but there are other utilities as well; open-source utilities. Unfortunately I can't remember the name of the one I'm thinking of.
Remember: You cannot connect a serial port directly to the UART. I recommend using something like the CP2102 module. They're fairly cheap (around US$2 only, or slightly more than £1, if you prefer British Pounds).
There is another option as well. Since you have the Raspberry Pi, you can use its I/O-pins to send data to the UART of the Cortex-M device you choose. This may be more complicated than it sounds, but if you can't get any USB-to-UART interface or a JTAG/SWD programmer, it should be possible to modify OpenOCD on the Raspi to be able to work as a SWD-programmer.
If you can receive packages from China, you can get a lot of good components, including a few ARM microcontrollers on eBay.
thanks, i already have an USB to UART (for my old avr )
so the question now is: where can i start learning how to program those? that board is even more expensive than the Pi its unlikely i will buy it but anyway, if he lets me i have to wait 2 months
and they can be programmer in C right? i don't have problem with learning asm but i still prefer c !
EDIT: it says its out of stock
but they had these : LPC1768FBD100-ORIGINAL the Chip itself
and the programming is same for all the boards with exact same chip right?! because if i got another board but with the same ARM Cortex-M !
btw i found another website which has this on stock and its cheaper :
http://eshop.eca.ir/%D9%85%D8%AD%D8%B5%D9%88%D9%84%D8%A7%D8%AA-eca/876-lpc1768-cortex-m3-header-board.html
how about this one?! and when i programm a Cortex-m3 from lets say Ti, the exact same chip but from Philips has different programming?! or its the same !?
The LPC1768 Header Board looks good for using on breadboards. It seems there is a on-board voltage regulator, which means it's probably powered from the USB interface of a computer (or a 5V MP3-player charger with USB-connector).
I think you can use FlashMagic too for flash-programming this board.
If not, you will always have the UART option - it's good to have more than one option, in order to get started quickly.
As you can see, there's a large black connector on the board as well. This is a JTAG and SWD connector, which is also used for flash-programming the lpc1768 on the board, that means you can choose which way you want to flash-program the board yourself.
In addition to the above, notice that each pin has the pin name written next to it, so it's easy to find the signals.
The designer also took some time to place the pins in a nice order.
So the board gives you freedom and good possibilities; I believe it would be a good purchase.
You can program the LPC1768 in C, C++ or assembler if you prefer. The choice is all yours.
If you decide to go for programming in assembly language, you will probably find the documentation at ARM Information Center interesting (Click Cortex-M series processors, then Cortex-M3 and r2p1.
I would say that the programming is very much the same for all chp-family members of one type, whichever board it's on.
When I say chip-family members, I mean...
This is because there is a 'core' on the chip, which is the instruction set, but each microcontroller family may have additional peripherals (functions).
For instance, one microcontroller family may have one 10-channel ADC, while another chip-family might have no ADC.
Or... one might have two 16-bit timers, another might have four 32-bit timers; setting up a timer would then require different code for the 32-bit timer, when compared to the code for the 16-bit timer.
In some cases, you might need the 32-bit timer because a 16-bit timer isn't enough in the particular case.
To make the answer more clear: Microcontrollers from NXP would be different from microcontrollers from Texas Instruments or ST-Microelectronics.
-Even microcontrollers from the same manufacturer would be different.
However... Writing code for a Cortex-M3 from Texas Instruments wouldn't be difficult if you've already written some code for one from NXP.
You will always need to read the documentation (eg. datasheet and User's Manual) for your microcontroller.
See for instance the datasheet and UM10360 for the LPC175x/6x family.
-But I would like to say that the LPC1768 is a good choice, it has a fair amount of features. You will probably not be using all features in one design.
It does not support external SRAM or SDRAM, and it does not have a built-in LCD-controller like the LPC1788, however, there are a number of LCD displays that do not require a controller, so you would be able to write code that could show something on for instance a SPI-based or parallel-interface LCD-screen instead.
Using this search phrase, I found another shop, where you can buy the same board for IRR 60000; to me, this sounds like a pretty affordable price for such a nice board.
Thanks a lot
it sounds like only need a 1~hour study to learn how to program other Chip (like when some timers in AVR had diffrent bits , it only took me 15mins to figure our how to use the other one (not only timer) from datasheet
also i will program on c:) and maybe use inline assembly sometimes !
so now i have 2 last final question:
i can't install linux on it right? becasue i might need to stream video to PC and it sounds pretty hard without Linux helping me i will learn A when i needed that ! or use samba (sounds like Raspberry pi will help me here )
im googling myself but if you know any good websites or book to learn how to use the LPC1768(i guess) ?
i found some persian tutorials there but i feel uncomfortable reading persian tutorials !!!
thanks a lot
that's same(50 rials = 5 tomans ) but thanks a lot for searching for me (and also i didn't know you can search like that thanks a lot ) 60000tomans = 19$
i gtg but thanks a lot i will order it as soon as i get money from my father and till than read some tutorials
lol my father also told me i can order 1 tomorrow
Tell your father that he's a good father.
Sorry for the mistake in the price; $19 sounds more correct too, but that's still a very low price.
lol thanks the main reason he had trouble paying me was he had some problems at work (he's machines at company were are burned and he was repairing them )
edit : sorry didn't see the earlier post thanks a lot xD
7kb/s download speed, i broke light's speed
i downloaded lpcopen_2_10_lpcxpresso_nxp_lpcxpresso_1769.zip
its lots of folders i randomly opened one and i didn't understand a thing ! but let me download the 300mb file first
edit: i donwloaded the other one (keil, in sublime this time, i kinda get how it works now, doens't really needs a tutorial(i assume ) let me look around a little, will post in this thread if had problem, thanks a lot
i just didn't understand stuff like SystemCoreClockUpdate (what does it do) or __WFI() but anyway i will search after i downloaded it and figure it out other stuff were pretty clear
