Cortex-M4 interrupts behaviour when same interrupt vector has multiple interrupts
I am using STM32F407ZGT6 Cortex-M4 microcontroller. This controller has same interrupt vector for 5 external interrupts i.e., NVIC (EXTI9_5) for EXTI5, EXTI6, EXTI7, EXTI8 and EXTI9 interrupts. They all have the same ISR EXTI9_5_IRQHandler interrupt service routine. So, one has to check the independent flags of each external interrupt to determine the source of the interrupt.
I am confused about how the service routine is called in case multiple interrupts arrived. Lets say, an interrupt due to EXTI5 has arrived, its interrupt handler is called and the interrupt is servicing. Meanwhile, EXTI6 interrupt is detected. Now, will the interrupt handler be called again when the EXTI5 interrupt is fully serviced or since it is already in the interrupt handler, it will not be called again?
In short, which method should I write among the following two styles:
void EXTI9_5_IRQHandler (void)
     if EXTI5 happens
          EXTI5 ISR
     if EXTI6 happens
          EXTI6 ISR
     if EXTI7 happens
          EXTI7 ISR
     if EXTI8 happens
          EXTI8 ISR
     if EXTI9 happens
          EXTI9 ISR
OR
     if EXTI5 happens
          EXTI5 ISR
     else if EXTI6 happens
          EXTI6 ISR
     else if EXTI7 happens
          EXTI7 ISR
     else if EXTI8 happens
          EXTI8 ISR
     else if EXTI9 happens
          EXTI9 ISR
Thanking in anticipation for your time and help.
