I would like to ask which version of gcc and with what flags , may I compile some c code to assembly code that uses arm neon coprocessor for ARMV7-A processor. Of course I want to use the processor itself but also the coprocessor. Is this gcc optimal?
Thank you
Thank you for the answer.
Is there LLVM support? OpenCL support?
The ARM Compiler 6 tool chain is based on LLVM, but currently that is aimed at ARMv8-A:
http://ds.arm.com/ds-5/build/arm-compiler-6/
I've not used the trunk version of LLVM, but looking at the Release Notes (LLVM 3.5 Release Notes — LLVM 3.4 documentation) the support seems to be there as well.
There's no OpenCL support via gcc directly. I'd suggest checking out pocl which you can download here...
http://portablecl.org/
HTH, Tim
