I would like to ask which version of gcc and with what flags , may I compile some c code to assembly code that uses arm neon coprocessor for ARMV7-A processor. Of course I want to use the processor itself but also the coprocessor. Is this gcc optimal?
Thank you
Thank you for the answer.
Is there LLVM support? OpenCL support?
There's no OpenCL support via gcc directly. I'd suggest checking out pocl which you can download here...
http://portablecl.org/
HTH, Tim
