Precise/Imprecise data abort in arm processor
Hi all
i am new ARM processor. Can anyone explain clearly in simple terms what is Precise/Imprecise data abort in arm processor.?
  • Hi Rakesh,
    Simply, a "precise" data abort is one for which it is possible to identify unambiguously the instruction which caused the aborting memory access. Correspondingly, an "imprecise" data abort is the opposite i.e. a data abort for which it is not possible to identify the instruction which caused the aborting access.
    An example of an imprecise data abort might be a data write which goes through a write buffer. In such a case, the eventual write to memory may come many cycles after the STR instruction which placed the data in the write buffer. In this situation, it is not generally possible to work backwards to identity the instruction.
    Another example would be a cache cast-out of dirty data. Again, if this causes an abort then it is not possible to identify the instruction which modified the data in t he cache at some previous time.
    I hope this helps.
    Chris
  • Hi Rakesh,
    I hope this helps.
    Chris
