Enable Reentrant interrupt handlers in kinetis K70
I have a TWR-K70F120M: kinetis k70 120MHz Tower System Module.
I have connected a elettric signal to PORTB and i have connected e isr handler to signal transition.
Electric signal
     _____          ______          ______
__|          |_____|          |_____|          |_____  ------> PORTB
  ( 1 )             ( 2 )                ( 3 )
Interrupt handler is called every transition of the elettric signal ( in the figure is 1,2,3 ).
The interrupt handler is the follow code:
#define EN_ERR_SCHEDULER_INT_TOO_LONG (10)
static bool wbFlag = false; /* control the reentrant function */
__ isr void isr_handler( void )
  /* l'interrupt precedente è durato troppo ? */
  if ( wbFlag != true )
    /* flag reentrant function  */
    wbFlag = TRUE;
  else
    vDebugPrint( EN_ERR_SCHEDULER_INT_TOO_LONG );
   while(1);
   wbFlag = false;
at the step ( 1 ) the program jump to the handler but not in the 2nd e third impulse. Is it possible to enable a reentrand interrupt in kinetis k70?
the setup is follow ( setup is call one time at the startup of the system ):
sllRq = 88; /*Port control module Pin Detect (Port B) */
void vEnableIrq (SLONG slIRQ)
  SLONG slDiv;
  /* Make sure that the IRQ is an allowable number. Right now up to 91 is
  * used.
  if ( slIRQ > 91 )
    vDebugPrint("\nERR! Invalid IRQ value passed to enable irq function!\n");
  /* Determine which of the NVICISERs corresponds to the irq */
  slDiv = ( slIRQ / 32 );
  switch ( slDiv )
    case 0x0:
      NVICICPR0 = 1 << ( slIRQ % 32 );
      NVICISER0 = 1 << ( slIRQ % 32 );
    break;
    case 0x1:
      NVICICPR1 = 1 << ( slIRQ % 32 );
      NVICISER1 = 1 << ( slIRQ % 32 );
    break;
    case 0x2: /* program execute this case !!!!! */
      NVICISER2 = 1 << ( slIRQ % 32 );
      NVICICPR2 = 1 << ( slIRQ % 32 );
      PORTB_PCR18 |= PORT_PCR_ISF(0) | PORT_PCR_IRQC(9) |  PORT_PCR_MUX(1);
      NVICIP88 = 0x00;
    break;
I need to control the reentrant interrupt because this application must check the excessive duration of the code in isr handler.
