Setting up IRQ in ARM
Hi everyone
I am new to ARM and really wanted to learn about various aspects of ARM Programming .
I have basic understanding of x86 Assembly.
So,what Specifically I wanted to know is what happens when an external device triggers an interrupt .
Let me put my basic understanding on the same, which I learnt in last few days
Offset Handler
00 Reset
04 Undefined Instruction
08 Supervisor Call (SVC)
0C Prefetch Abort
10 Data Abort
14 (Reserved)
18 Interrupt (IRQ)
1C Fast Interrupt (FIQ)
Whenever Interrupt comes instruction at address 18 is executed
So is it true that it is first instruction executed when interrupts comes??
Or as I read somewhere whenever interrupts comes first it moves from user mode to IRQ mode and cpsr is copied to spsr_IRQ but it happen without an instruction .
After that current instruction is replaced with a blx 0x18
How and where we do need to set the stack for different mode e.g for IRQ mode and Supervisior mode??
In the brancged code
IRQ_HANDLER:
SUB lr, lr, #4
STMFD !sp {r14}
bl IRQ_handler_to_specific_device ;it will branch to actuall hander code.
LDMFD r13!,{r14}
mov pc, r14
Is it all We need to do for setting up Basic IRQ handling ?
Also,how PIC/CPU comes to know that interrupt is coming from which device?
Amit Singh Tomar.
"ARM is taking over the world"
  • Absoultey thanks to you Niall.
    This is exactly what I am looking for
    I guess I can manage Stack alignment using below instructions
    and r4, sp, #4
    sub sp, sp, r4
    Only one doubt I do want to get cleared
    SRSFD #0x12!
    Is this Instruction is really required?
    Since we are not expecting any other interrupts here and it just a simple IRQ handler(not the nested one)
    So,why we do require to save the SPSR here.
    Also,I don't know how SRSED works, I mean how it pushes the SRSR and LR to IRQ mode stack
    Is #012 is base address of IRQ mode stack?
    and r4, sp, #4
    sub sp, sp, r4
    SRSFD #0x12!
